Old 08-12-2011, 03:57 PM
racepaul racepaul is offline
Default Starting troubles part II
At the advice of Ricknaz I checked my starting gears and low and behold one is malfunctioning. Below are some pics of the gear in question. The gear with the pen pointing to is spinning and the one behind it is not. It loooks like this gear set might come apart, but I had no luck. Any suggestions ?
Old 08-12-2011, 08:09 PM
ricknaz ricknaz is offline
This part is different to the one in later model bikes but it looks like it works on the same principle. It looks like the washer with the red arrow pointing to it has friction material on the back of it. There is one of these on the other side of the gear as well. Is the washer with the blue arrow a convex shape? If so, this is the one that applies the pressure that is supposed to prevent the gear from spinning. To increase the pressure I added another washer on top of the convex washer. There must be a small circlip that holds the assembly together. There is pressure on it so you'll need to use some sort of puller like I showed in this thread to pull it apart and get it back together.
Old 08-12-2011, 09:22 PM
You are absolutely correct, instead of a circlip it is bolted
together. I pulled it apart cleaned it and put in a thin washer. Any idea what that should be torqued down to? I'm affraid if I get it too tight and it backfires it will not do it's job.
thanks
Paul
Trail tech troubles skid jackson General Discussions & Announcements 8 06-02-2010 07:15 PM
Dunlop 803 troubles keeping it on kendunn Enduro Chassis & Body 15 04-22-2010 04:50 PM
troubles with.....something? kendunn Enduro Intake/Carburetion - 2 stroke 6 10-16-2009 08:48 AM
Tube troubles! Need help. svt2224 Enduro Chassis & Body 19 10-12-2008 07:50 PM
300ec 2001 Engine Troubles toka2020 General Discussions & Announcements 1 06-05-2008 03:46 PM
