What is this hole for and should it be filled?
On my ec 250 there is a small hole at the bottom of my crank case the same side as my oil drain bolt it looks to be m6 our similar and when the engine is flooded or leaks oil/fuel mix.. Should it have a bolt in? Any help welcome cheers
M6 for an oil drain bolt don't think so.
maybe it's the little hole under the ignition cover (LHS) to drain and let it breathe? |
broken down over 60 slow rider.. |
brilliant ta its the breather
Oil in the hole. | boyscout | General Discussions & Announcements | 21 | 07-21-2011 03:08 PM |
watch out for that mud hole! | stainlesscycle | Ride Reports | 7 | 07-16-2011 07:27 PM |
Bar mounts which hole | peanutsracing1 | Enduro Chassis & Body | 22 | 03-01-2011 03:26 PM |
Gas Gas gets the hole-shot | AZRickD | Pictures & Videos | 11 | 02-22-2011 06:55 PM |
M6 hole under engine? | moff747 | Enduro Engine - 2 stroke | 2 | 03-19-2008 10:48 PM |
