Showa fork swap complete - better photos added
Hi to All, I have recently completed my fork swap. The aim was to fit Showa 47mm TC forks to my 02 EC300 without butchering anything and still being able to go back to the WP 43mm forks if required. I am very happy with the result; it rides nice and high up in the stroke, glides over trail trash and seems to work better together with the Ohlins back shock, which I have just serviced. ?New? parts Forks: Showa 47mm TC ex 2007 RMZ 250, stock 0.44 springs ? completely rebuilt with new seals bushes, o-rings and Silkolene Pro RSF 2.5wt oil Triple clamps: 2005 RM250 22.5mm offset Triple clamp axle: Custom machined 7075-T6 alloy Triple clamp nut: Custom Machined 6261-T6 alloy Brake caliper adapter bracket: Custom machined steel Axle spacer ? left hand side only: Custom machined and ?blued? steel Steering stop: Custom machined steel and welded to frame. Fork Gaurds: 2007 RMZ250 - Yellow GasGas OEM parts used Front Wheel Front Axle Brake Caliper Brake line clamp Front Guard Steering Stem bearings, o-rings and dust cover. Last edited by Harry; 04-26-2012 at 03:00 AM. Reason: better photos added |
More photos
NICE JOB! Thanks for sharing. I need to get pics up too.
Very cool, give us a ride report...pics were a little tiny couldn't realy see much.
Sorry about the pics - I am still learning about this resizing thing. I will try and replace the photos with better ones. Any tips appreciated?
Better photos added Last edited by Harry; 04-26-2012 at 02:59 AM. Reason: Better photos added |
Neat, it will be easy to spot you at one of the epic event rides, blue gasgas, yellow fork guards..
I post photos by linking from photobucket.com Create account, upload untouched photos straight from the camera onto photobucket, copy the IMG code for a given picture and paste in a post here. Easy |
Very Nice! Thanks for the contribution. Maybe I'll do this to my '07 after I get the '12 dialed.
Very nice. Those of us with access to machine tools have the most fun tinkering with stuff. So enjoyable to turn ideas into reality.
2011 EC250E |
I have access to similar forks to swap with my 48mm Sachs on my '10 EC300. Sounds like a bit of mucking around for someone with no machining abilities.
Keen to get your thoughts on how it handles compared to your previous forks. Until then, will keep working with my Sachs |
In comparison to the WP43mm I had the improvement is like night and day. The WP used to beat me to death on the small chop and arm pump was a big issue. Showa's so far - no arm pump. |
Thread Tools | |
Display Modes | |
Been thinking- fork swap | BrentMartell | Enduro Suspension | 184 | 05-02-2012 07:57 PM |
WP fork swap | MonsterTruck | Enduro Suspension | 9 | 04-24-2012 08:54 PM |
????Complete Fork Disassemble???? | Wicitup | Enduro Suspension | 4 | 02-26-2012 10:02 PM |
Showa shock into EC 300? | Hamish | Enduro Suspension | 0 | 04-26-2010 12:57 PM |
