2011 Side Stand Spring Failure
Hi All, I had my side stand spring ('11 300EC Six Days) suffer a metal fatigue breakage (used my hand to lower the stand and watched it break)...just curious to know if any one else has had a similar experience? I would have gladly paid an additional $5 for the bike had it come with a decent quality spring!
I removed the stand alltogether, a stand failure at the wrong time can send you to the ground.
I try to eliminate what every I think might be a problem prior to a race. |
I'm no racer but I have done 5000kms without any issues on my 2010 (same chasis). Mind you I only put it down when I have to, and I never let it fling up under its own force (unless if it sneaks past me). I usually use my hand and ease it back against its own force.
Not a fan of these self retracting sidestands.....Looks like a bit of engineering is in order to change that on my '12......
I ride and race in some pretty tight nasty stuff, I have seen springs sheered off in a tight trail...that's the last place I want a side stand dangling from my bike...nor do I want to mess with it during a race. Imagine a spring popping off while jumping and the stand swinging down when landing...Ya I think I'll keep mine off. |
Need to engineer some sort of strap that can hold it up in place while moving like the ktm has. That way it won't fall down if the spring breaks....
BTW... my stand has been taken off the bike |
I'm with moto9, remove the stand, nothing good comes of it. I've done that on all my GGs. The woods are full of stands. For enduro gas stops I put it in the cooler with just the bolt in case all the trees are taken.
The 12 has arubber hold up strap behind the left number plate.
This topic shows a chain link fix for older bikes. No idea if applies to the 2012. Bevel the chain link holes so the spring hook doesn't wear too much.
http://www.gasgasrider.org/forum/showthread.php?t=8
2011 EC250E |
Thread Tools | |
Display Modes | |
Side stand spring | Rabbitist | Enduro Chassis & Body | 1 | 12-28-2011 10:53 AM |
2011 300 Chain Roller/Stand Failure Fix | coolum74 | Enduro Chassis & Body | 2 | 11-23-2011 06:53 AM |
