trials tire pampera
sjs
What trials tire would you recomend and why. How would you mount it?Should consider the maxxis EN tire.
thanks
TTs work great on the Pampera. Because the bike is so much lighter than the ECs, the IRC and Michelin work good where they are too soft on the ECs for reliability. Any one of them will work well except in sloppy mud. Pirellis are probably the most common now and easy to get. A little stiffer so I'd run less air. The Pampera is a light duty bike, so if ridden within its limits the tire will last a very long time. My wife's 250 Pampera has an IRC on it now with an MSR HD tube @ 8 PSI.
pirelli's are to tall and will rub the inner bottom part of fender.i would buy a dunlop trials tire. cost is much less than the michelin and works as well imo.
I don't mean to jack this thread but should i consider putting a rear trials tire on my XC 300? I ride in Colorado and we have a lot of rocks here.
in gunnison co i ran pirelli mt 43 on the rear with hd tube and 8 psi no issues.
at the same time had trials front tre wth tublss system at 7ps with no issues.
very muddy, pretty ruff, no issues.
great traction, loaded up in the super crappy mud at the same time and rate the nobbies were too.
i love trals and cant see no using them
