2012 frt disc guard
anyone know of front disc guard and does acerbis ktm guard mount work on 2012 gg
I have the Black KTM (which is actually made by Acerbis) one on my 2012 with a slight modification of axle spacer. The KTM spacer is same diameter but is longer in length. So took off about 2.5mm in order to fit.
Has anyone else done this?? It looks exactly like this one. http://shop.ktm.com/nl_nl/front-brake-disc-guard-1.html
2012 - XC 300 Racing Seattle, WA |
disc guard
How did you shorten the spacer?
white..... Sorry for never responding to this. Totally forgot.
I had a fab shop shorten the KTM spacer that replaces the OEM spacer. The spacers are the exact same diameter but the OEM one was just under 5mm longer then the KTM one. The fab shop and I determined that if we took a total of 5mm off KTM spacer is was going to put the disc guard a bit too close to the rotor. So ended up taking around 3mm off the spacer (the end that goes into the hub). Used a micrometer to make sure length was equal all the way around. Then replaced OEM Spacer with new one and works great. I am very glad I had this installed prior to riding in Easter WA at the Desert100. Otherwise I would have had sage brush, weeds, grass all stuck in front my front master cylinder.
Here is photo of the guard installed.
ktm disc guard
Thanks |
Fitting a rear disc guard | blanc | General Discussions & Announcements | 18 | 07-09-2013 11:06 AM |
Disc guard crossover | forgiven | Enduro Chassis & Body | 4 | 04-15-2011 04:16 PM |
Rear Disc Guard for '10 GG | 2whlrcr | Enduro Chassis & Body | 11 | 08-16-2010 04:48 PM |
Front disc guard? | Triple W | Enduro Chassis & Body | 0 | 09-22-2006 01:33 PM |
