Go Back   Rieju & GasGas Legacy Riders Club Forum > GasGas Enduro Technical Forums > Enduro Product Announcements
Enduro Product Announcements Announce new gasgas enduro products here - Vendors Welcome...
Old 11-19-2007, 02:05 PM
LAWMAN's Avatar
LAWMAN LAWMAN is offline
just talked to Gofasters, mine is shipping out today. I was told that the filter comes dry, i.e. no oil on it, which is just what I want, I like to use the biodegradable oil.
Old 11-21-2007, 09:24 PM
gasgasman's Avatar
Here are some shots of the cage and filter.
Updated filter for new cage.
This filter was pre-oiled.
Following photos show how the pins push out against the air box boot.
Old 11-21-2007, 09:26 PM
gasgasman's Avatar
With the stock cage, you can rotate it 2" within the air box boot. The Twin Air is snug. No movement.
Old 11-25-2007, 06:50 PM
SpeedyManiac's Avatar
SpeedyManiac SpeedyManiac is offline
What's the price tag on that cage?
Old 11-28-2007, 05:52 PM
LAWMAN's Avatar
got mine & it is indeed oiled w/ the twin air bio. does anybody know if that oil is compatible w/ the no-toil cleaner? I have a ton of no-toil stuff that I'd like to use.
the new cage is pretty much a work of art, looks like a real quality unit.
Old 12-09-2007, 01:59 PM
thelonius thelonius is offline
If you take the time to make sure the stock cage fits snug, isn't that enough? Yes, it is tricky and a very poor design but I have not noticed that mine "flops around". Has anybody actually witnessed such a thing? If I had money to blow OR if I knew this would harm my engine I would definitely buy it.
Old 12-09-2007, 04:02 PM
GMP's Avatar
GMP GMP is offline
The stock cage is OK IF your carefull. Plus, it seals on the flat and the inner edge of the airboot, the Twin-Air does not. What I don't like is the airboot being used as a sealing surface, as its not flat. I would rather have an alloy plate that goes over the airboot surface, a little smaller ID with three locating notches for the stock cage pins. I'm sure it would be less than $120 and use stock filters. JMO. Maybe I'll make a proto this winter.
Old 12-11-2007, 02:00 AM
DWreck DWreck is offline
I'd be happy with two locating pins like my KX had.
Old 12-11-2007, 03:30 AM
iancp5's Avatar
iancp5 iancp5 is offline
Far too blingy! And no one can see it.
What was wrong with the plastic ones - mine works ok?
Do some people get dirt past theirs?
Old 12-11-2007, 06:37 PM
GMP's Avatar
GMP GMP is offline
Its possible to not have the cage seated properly in the airboot even though it looks OK from the top. You have to get your hands in there and feel around the edge, don't trust a visual. Once its seated its fine. Just make sure your airboot lip surface is good with no imperfections.
which reeds/cage are best for ec200 2000? stainlesscycle General Discussions & Announcements 1 08-15-2009 04:56 PM
Twin Air Aluminum filter cage F_G Enduro Product Reviews 3 05-28-2009 08:19 AM
Reed cage removal skid jackson Enduro Engine - 2 stroke 6 03-26-2008 10:26 PM
50mm twin Chambers 05MC250 Enduro Suspension 0 12-24-2007 09:29 PM
