Old 03-16-2014, 05:03 AM
Default EC300 Supermoto conversion
Hopefully the gods of eBay will grant me a set of wheels, discs, tyres, spindles and spacers from a very common 17"er today (if not, another day very soon!!), in which this post will be my 'diary' for the process.
Stay tuned!
2016 RM-Z450
Old 03-17-2014, 09:38 AM
jt633 jt633 is offline
What is the benefit of the rm125 cdi?
2004 ec 300
Old 03-17-2014, 12:29 PM
The benefit is that the EC300 CDI stopped working , though 125's generally rev higher and are timed to suit, so my bike may have super powers, won't know until I dyno it one day .
Anywho, I lost bidding on the wheels, so I bought another set of the same ones .
GS500
First hurdles will be the discs
Front disc -
EC300 - 260mm
GS500 - 310mm
Rear disc -
EC300 - 220mm
GS500 - 250mm
I'll start with the rear, in which I will either turn down the OD and see if there is enough meat left for braking, if not buy this cheeky little rascal
http://www.ebay.co.uk/itm/2311266968...%3AMEBIDX%3AIT
and turn out the center clearance!
2016 RM-Z450
Old 03-17-2014, 12:57 PM
http://www.bikebearingshop.co.uk/C8.htm useful bearing sizes
2016 RM-Z450
Old 03-17-2014, 02:46 PM
Bearings required (to fit 20mm axles)
Front wheel, 2x 20x42x13 (60042RS), (this is supposed to be 20x42x14, but good luck finding that bearing, the centre spacer will be the same length, just the outer spacers +1mm).
Rear wheel 2x 20x47x14 (60042RS)
Cush drive 1x 25x62x17 (I'll keep this the same and make the spacer to fit)
2016 RM-Z450
Old 03-20-2014, 11:10 AM
WAZ WAZ is offline
I've just done a similar conversion to my EC300, but with Aprilia RS125 wheels. I originally started off with Bandit 400 wheels but they were just too much work to fit. If I can work out how to post pics, there should be a photo of mine below!
Old 03-20-2014, 02:45 PM
Very nice! Have you got any dimensions for the brake caliper adaptor at all? How does she ride?
2016 RM-Z450
Old 03-20-2014, 03:21 PM
WAZ WAZ is offline
I just made up the adaptor as I went along! The two holes in the caliper and the offset were easy enough to measure, then I bolted it on and marked the fork hole in situ.
Here's a close up:
I haven't had it on the road long, but first impressions are it needs higher gearing and stiffer fork springs. Other than that, its a right giggle on twisty bumpy roads!
Old 03-20-2014, 04:50 PM
gassergrant gassergrant is offline
hi mate I did this conversion, I used ccm wheels and complete front brake which is brembo, and is used by early 2000 ktm's.
merlin motorcycles in surry can get brackets to suit the nissin caliper.
I had to get dome spacers made for the front and change one bearing for the back to suit the gg spacers
03 ec300
honda cr500 94
Old 03-21-2014, 10:00 AM
slocalspode's Avatar
slocalspode slocalspode is offline
Smile GG SuperMoto
Nice to see SuperMoto bikes getting some love around here.
Looking forward to see your build reports.
Cheers, Jeff
Thread Tools
Display Modes
2002 450 FSE Supermoto conversion wakeymatt Pictures & Videos 0 08-05-2012 12:04 PM
Supermoto Conversion EC250 Ryan_250 Enduro Chassis & Body 6 05-16-2012 10:02 AM
Gas Gas EC300 2001 Supermoto maybe johns2394 Enduro Chassis & Body 12 01-29-2009 07:58 AM
2005 FSE 450 Supermoto Conversion reidnv Enduro Chassis & Body 7 01-01-2009 12:51 PM
