Old 08-22-2006, 06:23 PM
MattR's Avatar
MattR MattR is offline
Default FAQ: Premix Calculations
Question:
The GasGas manual specifies a premix ratio of 50:1 (or 2% oil). How do you determine the required amount of oil for different quantities of gas?
Answer:
The manual does specify 50:1. However, many riders have found other ratios such as 40:1 and 36:1 to work well in GasGas bikes. Personally, I like to use 40:1 in my bike. There are products on the market such as "Ratio Rite" which help riders determine the amount of oil per gallon of gas.
A better method for determining the oil for any quantity of gas is to develop your own premix table. Your premix table will allow you to determine oil for smaller quantities of fuel (such as emergencies on longer rides) or mix up larger quantities of fuel before a ride.
Here are premix tables that I have created for reference. I created tables for the most common premix ratios. You can print out these tables for your fanny pack or garage use.
Matt
Current: 2009 Yamaha FZ1
Old 08-28-2006, 11:35 AM
flybars flybars is offline
Default Premix Calculations
Sweet! Takes all the guesswork out of it. Eliminates mistakes.
'14 Beta 300rr
'05 GG DE300
'03 GG EC250
'01 XR440
'09 FZ1
Old 08-31-2006, 06:12 PM
tprnottp tprnottp is offline
Matt,
You be da man!
Thanks for doing the leg work for the rest of us.
TP
'03 EC 300
Old 09-01-2006, 07:37 PM
MattR's Avatar
Thanks! Glad you liked them.
Matt
Old 09-04-2006, 04:12 AM
Hawkeye Hawkeye is offline
My brother did a similar chart many years ago, but he just picked his ratio and then listed the oz. needed to mix with gas in tenths of a gallon. He formatted it out to look like a rollchart and then taped it to his front fender or his gas tank. When we trailrode, like the Six Days of Michigan, it worked great to get the proper ratio in your tank after topping it off at the gas pump.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
Old 07-23-2009, 07:06 PM
MattR's Avatar
Here is a table for 43:1 premix ratio:
As you can see, this makes it easy with 3 oz. per gallon.
Matt
Old 07-23-2009, 07:30 PM
Brian VT Brian VT is offline
I like the 3 oz. per gallon rate.
I pack an 8 1/2 oz. Listerine bottle of oil. It's flat and sturdy. I pour in oil and make marks for every 1 1/2 oz.
I've never used all 8 oz. but there always seems to be someone who forgot to pack oil.
Old 08-15-2010, 06:49 AM
lankydoug lankydoug is offline
If you're home and or have access to the internet here is a link that is useful. If I top off my fuel storage can before a trip I can enter the decimal amount and get the exact calculation as well
http://www.qddev.com/demos/sprockets...etpremix.shtml
Old 06-02-2011, 06:16 PM
GasGas's Avatar
GasGas GasGas is offline
Man I'm glad we went metric back in the 70's. All this stuff is so much easier to figure out in litres versus gal. When working in litres just convert to ml ( litres * 1000) and divide by your mix ratio. So for mix ratio of 36:1 for 20 litres of fuel just divide 20000 by 36 = 555 ml
2018 EC 300
Old 07-26-2012, 12:58 PM
steliost's Avatar
steliost steliost is offline
Hi all, I thought this would be the right place to post this. What do you think about 1.7-1.8 % oil ratio? The local gasgas dealer and mechanic, very experienced on riding, racing and maintaining 2 strokes mostly GG and Husaberg, swears by using 1.5% or 66:1 (!!!) on his bikes, even on his 125 2012 husaberg. His claims: less spooge, better performance without risking to seize the piston and bearings. Also he insists on Agip premix oil. What is your opinion on the subject?
premix W8TSON Enduro Engine - 2 stroke 31 08-11-2009 09:52 AM
what ratio to premix at? j@y Enduro Engine - 2 stroke 16 05-18-2007 09:53 AM
premix ratio for 300 two-stroke gateman Enduro Engine - 2 stroke 3 09-27-2006 06:29 PM
