Old 01-28-2015, 12:11 AM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Default 2015 marzocchi 48 changes
The 15s fork are very smooth, and felt different but similar to my 13 in stock form.
Relief taper from factory
Bushings are rolling like all other brands, see wear mark
Different rod and no shim baseplate.
Different spring seat that moved way easier
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 01-28-2015, 12:17 AM
Simmo737's Avatar
The cart appeared easier to bleed and didn't gurgle when turned upside down and stroked.
New base valve stack
12 .1
32 .15x2
26 .25 (no, that's not a typo)
24 .1
22 .1
20 .1
18 .15
11 .2x2
I went to:
24.1
32.15x3
26.25
16.1
24.1
22.1
20.1
18.1
11.2x2
It stops the late spike, and has the whole stack moving quicker, better grip and much better square edge performance.
I'd bet my bile duct that the mid is softer and rebound firmer than previous, so far no need to touch, may need to up the springs though.
Oz
1978 GT80 Yamaha
Old 01-28-2015, 01:15 AM
n_green n_green is offline
Interesting. Same stacks as '14 with the exception of the 26.25 obviously. Spring seat looks the same too and mine are always falling down when I'm trying to bleed them. Good to see the factory is listening and machining reliefs into the bush landing now, that saves $100 off the revalve bill.
Given you're the same weight as me I'll be watching this with interest. My forks were pretty good last ride, really showed the shock up as being too soft, especially in LSC.
Current:
2014 Gas Gas EC300R
_____________________________________________
Previous:
2011 Gas Gas EC300 ELC
2004 KTM 300 EXC
Old 01-28-2015, 01:42 AM
The cut out on that spring seat looks pretty shady Simmo. I hope you cleaned it up a bit.
Good to see they've obviously been listening to whats been said and making some changes. Wish mine weren't rooted during the development process, but what can you do.
Old 01-28-2015, 01:53 AM
Simmo737's Avatar
They were all like it, as if they were hand done to larger spec, it is a bummer about your forks, but you get to learn all about kyb I suppose. Sone sort of consolation.
Oz
1978 GT80 Yamaha
Old 01-28-2015, 04:34 AM
True that Mick! Just gotta set some time aside to open the KYBs up. Probably should do that soon. On holidays again in a week, so if the stars align the parts should arrive and I should be able to put some seat time down and get them fine tuned. Braap.
Does look like the spring perches were hand worked. I'd just clean the burred edge a little. I don't like what a small amount of swarf can do (not that it should rub on anything once assembled, but never the less).
Be interested to see what mid changes they've implemented.
Old 01-28-2015, 06:41 PM
Dirt Dud's Avatar
Dirt Dud Dirt Dud is offline
Oz can you share how much your weight is ? Thanks for the brilliant job on the forks !
IF I HAD ALL THE MONEY I SPENT ON DIRT BIKES , I WOULD SPEND IT ON DIRT BIKES
Old 01-28-2015, 10:49 PM
Simmo737's Avatar
I move between 95 to 100kg depending on how close to christmas
Oz
1978 GT80 Yamaha
Old 01-29-2015, 01:14 AM
twowheels's Avatar
I've got a set of '13s on the bench right now that has the land relief and the witness marks on the back of the bushings. The spring seat cut-outs were gnawed by a rabid gopher on these as well.
There are some other characteristics that I need to run to ground but I'll share them when I get them sorted.
Steven Beane #275
afterhourscycle.com
Old 02-01-2015, 09:02 AM
What is actually the purpose of the relief on the bush landing? To stop it binding in case there is a tiny lip there pushing the bush outwards?
2016 RM-Z450
2015 GasGas noobi General Discussions & Announcements 86 03-20-2016 09:22 PM
2015 GG 300 video gasgasman Pictures & Videos 7 01-21-2015 01:36 AM
2015 otd iamovru General Discussions & Announcements 10 12-21-2014 07:18 PM
2015 Husqvarna gasgasman All Other Bikes... 22 10-31-2014 10:33 AM
2015 MSRP for the USA Mark Berg - CPD General Discussions & Announcements 19 09-27-2014 11:55 AM
