Old 12-14-2015, 02:48 PM
booth booth is offline
Originally Posted by RockefellerGG View Post
Thanks. I found this video on youtube, and decided to give it a try: https://www.youtube.com/watch?v=oqGLErwkLFQ
Thanks for the video, already started sanding my pipe today and will complete tomorrow.
Spent day wiring up new switches and fixing wiring on my bike.
How did your frame turn out?
Old 12-14-2015, 04:51 PM
RockefellerGG RockefellerGG is offline
I'm very pleased with the frame. I'm just letting it sit for a couple more days to fully cure.
The subframe that came in the kit doesn't match up perfectly and will take some massaging to get it lined up. I just want to be sure that I don't do too much damage to the new paint.
I know nickel coatings are durable, but I wouldn't sand too deep! I had to go pretty deep on the rust pitting. I'm hoping that I wont see new rust spots where I went deeper.
Old 12-14-2015, 06:52 PM
rvangeel rvangeel is offline
Great posts and pictures. Keep them up. I'm planning on doing the same to my 05. I have the transformation kit on order now from motocrosscenter.com
Old 12-15-2015, 10:30 AM
Taped up the frame. I don't want to destroy all the hard work that went into the frame.
Engine back in:
I tried dying a few parts black using RIT dye. It worked on swing arm brake line clips, but not on the chain slider:
I'm waiting on new hoses, a pipe o-ring, and a new chain slider from T.M.
Old 12-17-2015, 01:30 PM
I apologize for hi-jacking your thread Rockefeller,
How my "2012 Six Days Kit" turned out:
[IMG][/IMG]
[IMG][/IMG]
Old 12-17-2015, 07:20 PM
Booth - That turned out great! I love this color combination. It really does something for me. Especially, the radiator and headlight plastics!
Who did you have do them?
Old 12-17-2015, 07:29 PM
So a question about the airbox and quick release for the airfilter.
The 2005 had a metal ring behind the airbox that had an index pin and a notch for the post to sit in. I don't see this on the 2011.
I can install the ring, but I don't see it on the diagrams for a 2011. What prevents the air filter cage from rotating? Just the pressure from the spring?
Here's a quick video to describe what I am looking at:
https://www.youtube.com/watch?v=d1xQhEX40hU
Old 12-17-2015, 10:25 PM
I am also searching for some other answers:
White hook: be215202511 is a brake hose guide and bolts into the upper triple clamp.
Red Aluminum Washer: Looks like it is used under the bolt that holds the seat down.
I'm guessing the longer bolt is used to go through the seat. But not really sure about the rest. I'll probably post this in the updated plastics thread too.
Old 12-17-2015, 10:35 PM
The black brackets are headlight holders. I found a part number on them, I can't believe I missed that earlier.
Still not sure about the little split anchor bolts.
I'm guess the silver spacer is used on the rear: perhaps it is part #49?
http://www.motocrosscenter.com/shop/...-plastic-parts
Old 12-17-2015, 10:39 PM
roverhybrids roverhybrids is offline
silver spacer is part of the seat bolt mounting.
Plastic anchor bolts are for the plastic to subframe
2011 GasGas ec300R
2011 GasGas ec200 Six Days
2005 EC250 Jetting theexception_03 Enduro Intake/Carburetion - 2 stroke 25 08-24-2012 07:57 PM
