Front disk guards - not for rocks
We're having one of the wetest years for a long time and I live in a sandy ground area. Whenever I have raced in the wet sand I have not finished because my front brake pads are gone in about an hour. I really can't be bothered to try and change pads, covered in wet sandy earth in the rain. I see a lot of US guys use disk guards but not convinced they will help my problem. I guess where you have sand in the US it's hot and dry so maybe you've not come across this problem. The races near me at the moment include riding in wet sand, like a thick soup where the bike is sinking in up to a couple of feet at times. Those that lose momentum seem to end up buried up to the tank in quicksand!
Does anyone know of any guards or some other way of keeping the wet sand away from the caliper? |
I don't like using front disc guards. On my 2001 XC250, I had a Devol guard installed and it like to collect/hold dirt. On my other bikes, they never had one and I wasn't bothered. Just my $0.02
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
damn sounds like you are riding in liquid sandpaper!!
I don't know that a guard will help with sand. I use it to protect from boulders trashing my disk, ripping my caliper off, grinding my computer cable, or gouging my lower fork leg. I've trashed a c.f. one each year so I think they serve the purpose. I'm trying a Hyde this year and I hope it lasts a bit longer.
Sorry I don't have any advice for sand. Maybe a different compound or disk ? I run a solid disk and see good life from my Dunlop pads. |
A front rotor guard will keep splash mud off the rotor and help protect the computer pick-up, but thats about it. If your in rotor deep ruts nothing will help, except hard sintered pads, but then your rotors wear out fast. I've always run an Acerbis front guard but not on the '07. Maybe I'll try the Hyde if Brian has good luck with it.
pads
A solid disc is a must and then experiment with pad compounds. I've used Braking CM-44 with good luck. Make sure that the caliper moves freely and that your caliper boots are in good shape. a dragging brake will wear pads quickly. Good Luck
Mike 01 Gas Gas 200XC 07 KTM 310 XCFW 05 Triumph Rocket III |
Thread Tools | |
Display Modes | |
broken genuine front Disk!!! | Klausen | Enduro Chassis & Body | 7 | 04-22-2010 03:36 AM |
cr disk guard? | eddy field1 | Enduro Chassis & Body | 0 | 09-22-2009 02:51 PM |
2008 Desert 100 - aka 100 miles of rocks and whoops | SpeedyManiac | Ride Reports | 5 | 08-03-2008 09:41 AM |
KTM disk guard fit GasGas? | slocalspode | General Discussions & Announcements | 2 | 01-16-2008 03:54 AM |
Hyde front disk guard | Brian VT | Enduro Product Reviews | 2 | 12-29-2007 08:41 PM |
