Old 06-18-2016, 10:39 PM
GGRider01 GGRider01 is offline
Default Pulling the right side cover without removing water pump cover?
Is this possible? I've had it off before and I'm having a major brain fart trying to remember if I need to pull the water pump cover off.
I just want to check things out in there.. have a rattly clutch that goes away when the lever is pulled in, so figured I'd check the basket out.
Old 06-18-2016, 10:53 PM
PEB PEB is offline
Several off the bolts holding the h2o cover on go through the side cover into the cases. Once all those bolts are out the the r side cover will come off.
Old 06-19-2016, 06:09 AM
Munch Munch is offline
I never take the water pump cover off when I am taking off my right side case, I believe it's one bolt going through the cover that goes into the case that you have to loosen same as the 2 in the clutch cover.
Old 06-19-2016, 08:49 AM
Zman's Avatar
Zman Zman is offline
Remove the coolant drain plug and let out about half of the coolant.
Lay the bike on the floor on the shifter side.
Pull the clutch cover.
Do whatever work you need to do, reassemble and refill coolant.
This will save oil, coolant and time. If you have the new metal shim gasket you can reuse it.
Old 06-19-2016, 09:25 PM
I ended up just pulling the small cover.. Nut is tight, basket doesn't wobble. I wonder why the clutch is so noisy until I pull the lever in? Basket looks like new. Granted, I don't really know if this just developed or not.. but I'd only noticed it in the last few months.
Old 06-20-2016, 08:33 AM
phoenix's Avatar
phoenix phoenix is offline
I'm no expert here, but our Ducati used to do that and being a dry clutch it was insanely loud. Forums suggested for that bike that the clutch stack height could be to blame. The dealers told us it was just "Ducati music" so we just ground our teeth and went on with our lives. You might look into the stack height thing, though, and make sure your plates are all within tolerance.
2009 Husqvarna TXC 450
2013 Husaberg TE 300
2014 Gas Gas XC 200
Old 06-26-2016, 01:27 AM
lxth7 lxth7 is offline
If the noise stops when you pull the clutch, would sound to me like. Gearbox!
Old 06-26-2016, 05:34 AM
Terrence R Terrence R is offline
I wouldn't worry about that noise. Honestly, my EC300 does it, and so does the majority of everyone else's. The noise goes away when u pull the clutch lever in, right? There's some threads on here that talk about it and it's never caused any issues (if it is in fact the same noise that I here). I also had a 2002 Honda CR125R that did the same thing. Ran it for years like that. The noise never got any better, or worse. It didn't effect performance at all.
Old 06-26-2016, 09:04 AM
Zman's Avatar
Yes it is common to the GG bikes.
Water pump impeller contacted cover VxZeroKnots Enduro Engine - 2 stroke 1 01-23-2015 06:48 PM
Water Pump Cover, Impellor, Gasket- ALL NEW! mcnut Parts 0 12-08-2014 06:28 PM
Water pump cover fiber gasket r00zter Enduro Engine - 2 stroke 6 04-28-2012 03:59 PM
Removing '05 airbox cover Trooper Sam Enduro Chassis & Body 7 01-23-2012 11:19 AM
