Old 02-11-2008, 08:03 PM
ramcclure200's Avatar
ramcclure200 ramcclure200 is offline
Default Fork seals, Do I have them installed correct
I have leaking forks and someone said I might have the seals installed upside down.
Forks are on 2004 DE200.
Please view pictures at http://picasaweb.google.com/ramcclure/ForkSeals
you can use magnifying glass to enlarge, and refer to captions.
Seals are new and only had 10 miles on them when they started to leak so I removed and inspected and reinstalled and rode again and still leaked so someone mentioned I might have seals in upside down.
Before I flip the seals I was hoping someone will know by looking at pictures so I can put them back togther and enjoy some riding.
Old 02-11-2008, 09:21 PM
Brian VT Brian VT is offline
I have a new set of Moose seals here that I was hoping would help me help you.
It has a diagram on the package and it says "double lip side torwards oil".
As I see it, the arrow in my exagerated sketch points torwards oil. The angled lips I drew are on the inside diameter of the seal.
Old 02-11-2008, 09:56 PM
GMP's Avatar
GMP GMP is offline
The hollow side with the tension spring is always toward the inside of the fork.
Old 02-11-2008, 10:15 PM
The Moose spares I have are open on both sides and have springs on both sides. They're almost symetrical unless you look close. The ones I have in the forks are as you describe, open w/spring on one side.
Old 02-12-2008, 06:29 AM
one side on my seals is more open than the other and that side is facing down so that means I did install them upside down.
Thanks a Bunch.
Fresh Motor Thanks to Jack Bondus, fresh suspension, weather in the 60-70 degrees, correction will be made and I'll post update after riding this coming up weekend.
Old 02-12-2008, 08:36 AM
GMP's Avatar
GMP GMP is offline
I heard some not so good things about the Moose seals. I just go OEM. Any problems?
Old 04-13-2008, 08:33 PM
I've got a leaking (OEM) seal. I've got these Moose seals sitting here but I'm scared to waste time installing them if they're junk. What to do ?
Old 04-13-2008, 08:59 PM
install them and find out if they are junk!!!
Old 04-16-2008, 11:08 PM
CACTUSREID CACTUSREID is offline
widebears tip here for you: alway's use a plastic baggie on the end of the fork tube as you slip the seal over the end of the tube, they can be damaged very easily and a oiled plastic bag helps a lot in letting the seals slip over the tube without damage.
Old 04-17-2008, 05:57 AM
Yup. Poor man's bullet tool.
help on WP 4357 fork seals. asshat Enduro Suspension 1 06-17-2008 01:56 PM
Fork seals Iron Hide Enduro Suspension 2 02-22-2008 12:45 PM
wp fork seals dlwheaton06 Enduro Suspension 4 12-23-2007 06:34 AM
