Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 07-23-2017, 01:44 AM
Moto7man Moto7man is offline
Rekluse EXP,Rekluse Torque Drive Clutch Pack, Boyesen Super Cooler with clutch and ignition covers.
―Comedian Lewis Black
-Unknown Sardaukar
Old 07-24-2017, 09:49 AM
The Rekluse kit came with these new steel U wedges that clip into the clutch basket. In the above photo you can see the steel wedges pressed into the new recluse basket. Sorry the pictures are so huge, I am still learning how to post from Imgur.
-Unknown Sardaukar
Old 07-24-2017, 10:03 AM
Default Engine Assembly on the Beast.
Honda has specific depth specifications for the crank seals. On this side the seal must be 2mm below the crank case surface so a case splitting tool is used to set the seal depth, Per Dogger315.
This is the cases before the clutch install with the spacer and bearing installed.
New recluse clutch basket.
New washer for the retaining nut.
-Unknown Sardaukar
Old 07-24-2017, 10:15 AM
These are the new Rekluse steel wedges for the clutch basket.
Steel wedges installed in the clutch basket.
New Honda inner clutch and pressure plate.
Clutch holding tool.
Clutch nut torqued to spec.
-Unknown Sardaukar
Old 07-24-2017, 10:25 AM
Default Boyesen Super Cooler
Right side case cover and Super Cooler assembly and Boyesen impeller installed. The impeller screwed onto the Honda pump assembly but be careful, the nut cast into the impeller is a std size and not metric, don't ask me why?
Super cooler mounted up. The cooler comes with its own gasket, so the two Honda gaskets with the metal separator plate are not used. Also, the kit comes with a black rubber cover and hose clamp that shut off the stock Honda return line.
-Unknown Sardaukar
Old 07-25-2017, 10:43 PM
Default Power Valve Pinion Cavity Probe to Air Leaks?
I am getting ready to install the top end tomorrow. In the photo above you can see the lower power valve shaft in the corner of the case surrounded by a cavity. I have installed new bushings on each of the pinion shafts for the power valve actuation mechanism. I have read that there can be a air leak through the power valve pinion cavity unless the cavity is packed with moly 60. Is this correct?
Here is a photo from another site with the proposed fix.
-Unknown Sardaukar
Old 08-07-2017, 10:53 AM
Default CR 250 Wide Ratio
Ok, I got a lot done this weekend. This is where I started on Friday night.
I used an 18mm Bux Tool to install the circlips in the Wossner B piston. Its takes about 45 seconds per side, this tool is awesome!
The barrel went on without any problems, I set the ring end gap at .4mm.
Per Dogger, I preloaded power valve at .5mm.
I installed a new Honda oem head. I did not have it milled yet because I wanted to see how it runs in the stock configuration.
-Unknown Sardaukar
Old 08-07-2017, 10:59 AM
Head torqued down to Honda specs.
Countershaft installed with cad plated washer and new oem bolt. I used a clutch holder to secure the countershaft as I torqued it down to spec.
Engine ready for install into the frame.
-Unknown Sardaukar
Old 08-07-2017, 11:01 AM
A couple more shots of the motor.
-Unknown Sardaukar
Old 08-07-2017, 11:09 AM
Motor in the frame.
New Honda OEM radiator cap.
YZ450F rear brake pedal fit great but the stock return spring won't clear the case, I need to find an alternative.
-Unknown Sardaukar
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
