Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > Other GasGas Bikes/Quads
Other GasGas Bikes/Quads Trials, Pampera, Wild HP, etc.
Old 06-14-2018, 02:16 AM
Andy92 Andy92 is offline
Default Wild hp 300 sprocket Carrier interchange
Wondering if anyone has any info on if there is any other quads that share the same size/spline on the axle for the sprocket carrier, I know the banshee is also a 25 spline but not sure if it is the same diameter shaft. If anyone can share any info it would be greatly appreciated!
Old 06-15-2018, 11:10 AM
jcs003 jcs003 is offline
possibly one of the Honda models. trx250r/400ex/trx450r
Old 06-15-2018, 11:11 AM
i am looking for a gasgas 300 pipe. know where i can find one?
Old 03-19-2019, 12:33 AM
Default TRX450R axle swap in wild hp 300
After months of searching the internet for rear brake parts, sprocket carrier and different sprocket sizes with no luck I noticed the TRX450R takes the same axle bearing, lucky for me I have a 2004 trx, so I started doing some measuring and decided to disassemble both quads and see if the trx axle and components would fit. What I determined is everything fit right on even the caliper mount. The only thing I had to do was grind about 1/8?-3/16? off the outside of the brake disk carrier.
Old 04-22-2020, 07:59 PM
ktmbk ktmbk is offline
I recently talked to one of the fellas at Durablue about an axle on my wild 300.
The axle itself was based on a Honda trx400ex unit. Of coarse some dimensions were changed but its a good starting point to figure out interchanges.
Gas Gas wild 450hp sprocket question DRAGONFIRE Other GasGas Bikes/Quads 4 04-19-2014 05:17 AM
Best Class 3 hitch carrier? brider General Discussions & Announcements 20 04-09-2014 06:12 PM
Rear sprocket interchange motopsycho87 Enduro Chassis & Body 0 03-19-2014 04:20 PM
Rear wheel and Sprocket interchange? motopsycho87 Enduro Chassis & Body 4 08-31-2013 04:00 AM
Wild axle bearing carrier crossover pete8 Other GasGas Bikes/Quads 0 03-12-2013 05:10 PM
