Old 12-21-2018, 07:29 AM
Wypipo Wypipo is offline
Default Tips for changing springs.
I will be changing my fork springs and rear springs for my weight and have never done them on any bike before. What are some things I need to know before changing? Will I need new seals too and oil? The bike only has 15 hours on it, maybe less.
Old 12-21-2018, 12:01 PM
gasgasman's Avatar
Nothing special about changing the springs. Do a fluid change on the forks.
I would get the XTrig rear shock preload adjuster. Well worth it!!
Old 12-21-2018, 03:01 PM
dzhitshard dzhitshard is offline
https://www.youtube.com/watch?v=hc5TTiCvops
Simple search, simple tool collection, simple task.
Any Yamaha KYB tools you need can be acquired with immediate delivery on from a plethora of online retailers.
Old 12-21-2018, 07:02 PM
SS109's Avatar
SS109 SS109 is offline
Changing springs is pretty easy. Just locate a video that covers your particular forks, gather the correct tools, and get it done. The video I did on my Zokes was only the second time I have ever been in a set of forks so don't be intimidated.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 12-22-2018, 03:48 AM
What suspension do you have?
Just a question... does rider weight (and change to proper springs) have an affect on the valving?
2003 txt250 Pro
2013 Ossa 280i
Old 12-22-2018, 01:11 PM
Mikeyx Mikeyx is offline
For the rear shock you'll need a spring compressor. Automotive compressors tend to be too large in size. You'll also need to figure out how to release the bottom flange.
Fork springs are easy. Just open the caps and replace the OEM's.
Old 12-22-2018, 02:36 PM
gasgasman's Avatar
Kyb rear shock has enough threads , you don't need a spring compressor.
Old 12-26-2018, 02:32 PM
does anybody happen to know the oil capacity for the shock? I do not see it in any manuals. Also I watched a video for changing fork oil and it the one I saw there was 2 different places where the oil was drained, and then re filled with 2 different capacities. In the owners manual it says the fork oil capacity is 950 ml. I have never changed fork oil before. Does all 950 ml go into one reservoir or are there separate places that need the oil added?
Old 12-26-2018, 09:42 PM
Unless you have the proper tools to recharge the shock with nitrogen, you don’t want to open it up. You will also need a few special tools to change the oil in your fork cartridges. If you’re only doing springs, you don’t need to open the cartridge and you will just drain/refill the oil on the fork tubes which takes 350ml
Old 12-31-2018, 12:44 PM
What size cap wrench do I need for the forks? I can find 50 and 49mm. Also is KYB 01M the oil to use? There are no different oil weights to choose from?
Thread Tools
Display Modes
Changing Oil Henningway Enduro Engine 4 stroke (including EFI & Exhaust) 0 05-01-2013 04:23 AM
need help after changing mains i3uddy123 Enduro Engine - 2 stroke 7 06-22-2012 12:22 PM
Changing to Gas Gas? Need Insight... Bulldog General Discussions & Announcements 10 11-05-2010 08:04 AM
Changing fork springs skid jackson Enduro Suspension 11 09-25-2008 08:26 PM
