Old 11-03-2019, 05:51 PM
TBUBBA TBUBBA is offline
Default Blowing fuses 2012 ec 250r
I keep blowing the relay fuse under the seat. I bump the starter each time I change the fuse and it turns, I don?t cold start with the starter, but into my ride it blows the fuse and the starter quits working. Any ideas what it could be or how to troubleshoot.
Old 11-03-2019, 05:59 PM
gasgasman's Avatar
You need to find out what circuit that fuse feeds.
Take a lower amp fuse, install it.
Just start moving the harness around until the fuse pops.
That's where the short will be.
Old 11-10-2019, 05:14 PM
Solved. The extra wire in the tail light area (assume it is there for a license plate light) was flopping around inside the fender and shorting on one of the bolts on the taillight. Taped the end of it up and all is good
Tags
fuse, starter
blowing bulbs dimtsam Enduro Electrical & Wiring 18 09-22-2019 12:06 PM
gas gas ec 300 2015 blowing fuses! Munch Enduro Engine - 2 stroke 3 07-07-2017 10:14 PM
'05 EC300 Keeps blowing bulbs siaknijustin Enduro Electrical & Wiring 5 10-02-2014 07:07 PM
EC-400 FSE - Identifying Fuses lukemillar Enduro Electrical & Wiring 4 07-08-2013 03:17 PM
'12 250R is in the house GMP General Discussions & Announcements 66 07-03-2012 11:55 AM
