Old 07-07-2021, 10:33 AM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Hello
How do you reverse polarity on the ebay starter ?
Old 07-07-2021, 05:54 PM
fred99999au fred99999au is offline
Need to rotate the magnet shell or main body by 180 degrees.
Old 07-07-2021, 07:42 PM
Stoby's Avatar
Default Starter
ok took apart - put back together which way should it spin to work ?
Old 07-07-2021, 11:55 PM
Gez Gez is offline
There was a good video showing this. I think I linked it earlier in this thread.
Old 07-08-2021, 05:20 PM
Stoby's Avatar
Default starter
found video . problem is i took apart and put back together dont know how its clocked . So should it spin clockwise or counter ?
Old 07-11-2021, 06:05 PM
Gez Gez is offline
Finally had a good test of my 24v starter system in a race last weekend. Faultless, started cold in seconds. Started in gear etc. Its worth doing IMO, I just used a Honda Z50 battery which is a AGM not lithium. I will be riveting some proper terminals onto the spade connectors eventually. I might even 3D print a little holder for it instead of the zip ties.
Old 09-20-2021, 05:24 AM
Duster Duster is offline
I had a lot of different issues with my e-start. my2018. New bendix cover with bearings help a little and all the bearings must be in very good shape. My problems ended, when added li-ion battery, 48wh. This starter s?stem doesnt work, if battery voltage is below 13v on mine, it doesn't care about starting amps very much. If battery has more than 13v to give, it starts cold, hot, ingear, no problems whatsoever. If voltage is below 13v, u may forget u have e-start, even diesel car battery with 800A starting current straight to starter motor makes only clanking sound, if below 13v.
My sisters boyfriend has same bike, his is acting the same. I interchaged many parts between them (mine had issues, his didnt) and last thing was battery, a fully charged one.
One problem still exists, battery charging is too a little bit low on my bike for getting 100% from the battery. I belive the starter engine is wrongly built inside, is there too many or less roundings on the copper wire or are they too thick or thin, i dont know, but it should be possible to rewire them to work higher rpm's on 12 voltage.
24v system was on my mind also, and i'm sure, it helps, but i dont want to carry 2 batterys and make electrical system more complicated, this bike needs simplicity. Rewiring starter motor should do the trick, do we have anybody who is very familiar with electric motors?
Old 09-07-2022, 05:26 AM
BillH BillH is offline
Originally Posted by Doc Brown View Post
Check this out, its the bendix cover of a new Rieju 300
Hi Doc, I'd heard these were on the way but not seen one yet, any chance you can tell me what he bearing number is, I cant read it from the picture.
Bill
Old 09-15-2022, 10:45 PM
ditezz ditezz is offline
It will eventually brake the woodruff key on your flywheel .A Genuine Reiju starter,A reiju bendix cover and the wet mod (if its pre 2022 reiju will fix all starter issues.Will start hot or cold ,even when the bike is side down
Old 11-07-2022, 05:47 PM
rvktm rvktm is offline
Default my cunning plan
just got a well used 018 needs rod crank bearings all the link bearings /swing arm . @@@@ surprise no e start workey my plan new rj cover my one worn out on the small hole . all the parts are ok ish going with them for now think the starter is a ktm ebay one .looking at all the info setting the gears to spin freely is the key . gasket thickness important? ring gear shims ? its got the thinker cable dont no if the cdi has the mod any way of telling thanks for any help
Thread Tools
Display Modes
Wet mod for 2018 starter GG221 Enduro Engine - 2 stroke 20 12-05-2022 07:51 PM
2018 ec300 starting issues! Wtf. Steveheritage General Discussions & Announcements 17 09-05-2018 07:52 AM
05 300ec Turn Signal Issues natem77 Enduro Electrical & Wiring 1 04-05-2017 05:14 PM
Looking for electric starter for 300EC 2012 oran "Wanted to Buy" & "Want To Trade" 0 01-09-2016 02:33 AM
Electric Starter pictures 2011 300EC gasgasquebec General Discussions & Announcements 70 12-04-2011 10:01 PM
