Clutch not engaging - 06
Hi, I cannot get my hydraulic clutch to work on my EC 125 2006.
I have tried to bleed it many times and it has quite good pressure in my opinion. Also I have ziptied the lever to the handlebars for like 2 days but doesnt help. I can hear the clutch springs release on the bike when I pull the clutch, and it almost Works but it still doesnt engage fully since I cant stop freely without the bike stalling, kick it in gear or shift freely. Is it still air in the system? Why doesnt it work? The lever has full range of motion and good play since I adjusted it. I mean either way, I shouldnt have to pull the lever all the way in, it should engage like mid way. Its way easier shifting that way aswell. My guess is that I cant bleed but ive tried multiple times. I need help from the pros 😅 |
So it should have mineral oil in it not brake fluid I assume, but not sure for 125.
On filler cap it will tell you. If you've put the reverse in you will need seals.
'07 EC300 GG '14 TXT250 GG '? 496 CPI Cheetah RZ/RGV hybrid '22 765 Street Triple RS '21 XTrainer '69 Stinger T125 Suzuki '23 TRS 250RR (it's a Trials thing) |
Since its an 06 im using brake fluid. I have a black cover.
What do you mean that I need seals? |
Oh my days. I am looking at enduropuro and it says that they use dot oil for models to 2005. Meaning my 2006 will need mineral.
Though my cap is black and says I need dot 4, but I am starting to think that some previous owner has made a mistake and bought that one, or because it is cheaper, cause it the end they are the same. I think I am going to try to use mineral oil. Now, what seals do I need to replace? Not leaking anything. I do have extra O-rings for the slave cylinder. Edit: No, my thinking must be incorrect. If I was using the wrong fluids, seals would have failed and it should be leaking, but it isnt so it must be brake fluid Last edited by Noobi06; 06-26-2023 at 07:54 PM. Reason: Nvm |
You can only trust the cap, it would be unfortunate in the extreme if some clown swapped it.
My slave had two o_rings on the slave. Try that if you already have them. Then look at rebuild of master cylinder. The adjuster should have a little play but adjust it in a bit to see if you are there. Parts diagram is always good to see if there's a shim or ball bearing you might have missed in the clutch assembly or pushrod etc.
Those can be very hard to bleed.
This is the regular way on an 07 Gasser. https://www.youtube.com/watch?v=zbnN9nD90WA This is a Husky https://www.google.com/search?q=magu...id:bmuN0o24FtI
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
Its a Pain Sometimes
On my 2011, I pumped my clutch lever until I was blue in the face. I had to back bleed mine with a syringe.
https://jj-motorsports.com/magura-sm.../?sku=38080028
I went through almost the same thing on my '11. I could feel the clutch m/c push the clutch but not enough. I tried everything and nothing worked. Ended up figuring I needed to rebuild or replace the master. Bought a new master through CPD and all is good now.
WildAzzRacing YouTube channel Trail Riders of Southern AZ club AZ State Parks OHV Ambassador '11 EC250R '98 KDX220 |
Swollen????
I dont know what to do from here to be honest. Im trying to spend as little as possible, at the same time im trying to get this finished within 1.5weeks since im taking my license and I want to go riding with my friend.
Is this M/C seal swollen or is it normal? If it is swollen, I need mineral oil, else, I think the clutch needs better bleeding. Also. When I ziptie the clutch to the handlebar over night, and next day, still ziptied, the clutch seems to be good since I can e.g kickstart in first gear. Though when I release the ziptie and pump the clutch 2 times, its like normal again. Just wondering if that could mean something. I think im just going to let someone better bleed this for me though so I know if that's the problem we.jpg w.jpg |
Sounds like it needs a rebuild.
Can't tell from your pics if they are swollen. What does your cap say on top?
Thread Tools | |
Display Modes | |
Clutch washers like Beta guys use to make light clutch feel | Dingo_ed | Enduro Engine - 2 stroke | 3 | 11-19-2018 03:15 PM |
Fixes for intermittently engaging 2t electric start | stay_upright | Enduro Electrical & Wiring | 4 | 02-10-2015 12:53 PM |
Clutch lever doesnt release clutch as soon as motor starts | cal_tony | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 05-19-2012 08:59 AM |
Hydraulic Clutch on EC 250 not engaging | jprh | Enduro Engine - 2 stroke | 2 | 03-01-2009 05:54 AM |
