Plagued with chronic weak power?
The cause is likely to be that the cylinder is sitting quite low.
Contacted Bob of North Tahoe MotorSports. He wasn't surprised when my concerned brother ask about raising the cylinder/ports .095". Bob said he was on the right track and that he can provide custom gaskets of .035" and .057". Well now, that's .092" init. My brother also found that the case/cylinder base was a poor match. He had to remove 3/16" from the cases! Yee-haw, this thing rips now and easily pulls 6th gear with authority despite a 13/44 sprocket set. The 44 was the previous owners solution for an extremely short p/b. He said it was for the dez. Just got a 12T c/s and a G2 throttle. Check yours by removing the head and cranking the piston down to BDC. Look down into the transfer(side) ports to see where the top of the piston is in relation to the bottom edge of the port. It should be even with it. Last edited by socalscott; 11-27-2008 at 03:17 PM. |
What the FARC?
Lately I have seen a lot of talk of the cylinder being to high or too low. How do you know if it is at its correct height?
Eric P. SoCal MC AMA D-37 2004 KTM 400 EXC | 2001 GG 250 MC | 2001 GG 200 EC (wife's) | 2000 Montesa Cota 315 | 1967 Lambretta Li 125 "Special" |
Why not just adjust the head squish?
2002 Gasgas EC250 (gone not forgotten) 2012 Ktm 300xc 2001 Gasgas EC300 Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!! |
Adjusting the squish would not move the piton in relation to the ports, something I thought the factory got right, but not according to socalscott. Tell us more Scott.
Well, as I mentioned. According to Bob of North Tahoe Motorsports 'we are on the right track'. Did I mention he sells the thick set of gaskets?
BTW, He also mentioned getting the squish gap down to .051" or .052" is a good idea. I'll defer to Bob. http://stores.ebay.com/NORTH-TAHOE-M...dZ2QQpZ2QQtZkm |
How good is this bike off the bottom ? This whole deal that you have done raised the port timing considerable and I would think that the bottom power would be sacrificed. Have you had it on some tight trails yet ? Thanks
There is more on this from Scott in the general discussions.
Crawled up some step, technical climbs with no sign of weak bottom.
What are you guys riding that makes you want more top end?
Desert? My 300 would hit 70 mph (13/48) and pull strongly on the way. Here in the UK there was only 1 event where I had it tapped out. I'd guess most I do we never exceed about 50 mph and average speeds are closer to 15 mph! We do have some Rally type events in the forests that have lots of fast fireroads but to be honest I get queezy above 60 mph looking at steep drops off the side of bends with trees and tree stumps everywhere! Occasionally people go over the side and it never ends well. Usually they lay them down first or they'd sail so far out they'd have a few hundred foot drop at 70 mph. |
Thread Tools | |
Display Modes | |
FYI, Cylinder/Case mis-matching, 3/16" off! | socalscott | Enduro Engine - 2 stroke | 4 | 11-26-2008 06:44 PM |
Questions RE: "B" Cylinder | PBWR450 | Enduro Engine - 2 stroke | 8 | 11-19-2008 10:16 AM |
Anyone have experience with "Power Now" carb plates? | bondo | General Discussions & Announcements | 9 | 12-12-2007 04:53 PM |
Recommendation: add "Injury/Recover" and "Riding Techniques" sections | MattR | Suggestion Box | 2 | 07-18-2006 09:19 PM |
