Old 01-08-2009, 02:43 PM
darren's Avatar
darren darren is offline
Default EC250 1998 workshop manual
Does any one have a workshop manual for a EC250 1998????
I found a 2003 manual on line but its too new..
thanks
darren
Old 01-08-2009, 03:09 PM
PEB PEB is offline
Very few if any major changes beside the newer manual is all you will find.
Old 01-08-2009, 03:22 PM
darren's Avatar
Main reason for askin is in the 03 manual the left hand cover revealing the rotor looks different to mine. and what looks like a counter balance shaft. which is not in the manual. I was curious as to how to remove the rotor. In the manual the rotor covers the coils but on my 98 the coils are housed in the casing and the rotor is bolted onto the crank. I was wondering if there is a special tool for removing the rotor.
Old 01-08-2009, 06:51 PM
JEEPUSAURUS JEEPUSAURUS is offline
The '98 has a lighting coil on the outside of the flywheel in the housing(it's a ducati lighting coil), The piece That goes inside of the coil will unscrew from the flywheel,(lefthanded threads), then you use a flywheel puller on the flywheel, it's the same puller as most jap bikes, suzuki for sure, in fact the ignition stator is the same as '91 -'95 RM, I've taken them out of an RM and bolted them right in the gasser without any mods, and the same flywheel as the RM 250 from the same'91-'95
99 EC 300
Old 01-08-2009, 07:30 PM
MattR's Avatar
MattR MattR is offline
Here are links to the 1999 manuals (in english). I'm assuming the 1998/1999 will be the same. This is the only source I found for these. The quality of the early parts manuals is marginal, but it is better than nothing.
http://212.166.128.102/GASGAS/1999/ec1999_engine.pdf
http://212.166.128.102/GASGAS/1999/e...rame_print.pdf
Here is the website in case the links above do not work (note: it is a spanish website).
http://www.embarrados.com/gasgas/viewtopic.php?t=958
Matt
Current: 2009 Yamaha FZ1
Old 03-26-2019, 09:19 PM
Banditpowdercoat Banditpowdercoat is offline
Bumping this so I can find on my laptop and try links later
Old 03-26-2019, 10:17 PM
Guess they not working no more. Anyone have a link to 98/99 manuals?
Old 03-27-2019, 10:48 AM
slocalspode's Avatar
slocalspode slocalspode is offline
I have a .pdf of the motor, but, not the chassis.
It is a "parts" list with exploded diagrams.
PM me an email address. It is just under 1 mb.
workshop manual 2stroker Enduro Engine - 2 stroke 3 10-30-2008 10:21 AM
workshop manual 2stroker Other GasGas Bikes/Quads 0 10-27-2008 07:15 PM
Workshop Manual GG FSE450 '04 & '05 timw Enduro Engine 4 stroke (including EFI & Exhaust) 6 08-01-2008 12:52 AM
Workshop manual rupecopp Enduro Engine - 2 stroke 1 10-04-2007 03:59 PM
Where to post workshop manual PDF's? Radbuster General Discussions & Announcements 8 07-16-2007 01:51 PM
