Old 12-06-2006, 11:33 PM
MIKEWA MIKEWA is offline
Question Zerex Dex-cool
ZEREX DEX-COOL antifreeze contains no silicates,phosphates,borates,
nitrates,amines. Is this ok to use in my 05 gg 300 ?
thank you mike
Old 02-21-2007, 10:16 AM
42GEORGE 42GEORGE is offline
Question why bother?
Has anyone here ever heard of EVANS NPGR "waterless" coolant, this stuff is amazing, it has boiling point of 400F degrees and is good down to -10F, and when it does go below -10 it actually shrinks instead of expanding. What else ? Well, it's good for 100,000 miles! So Evans reccomends draining it into a clean pan (no matter what color it comes out) and re-using it for 100,000 miles. It goes for about $38.95 per/gal but this will do 2-3 bikes depending on size & coolant capacity and its well worth it, especially for those on 4-strokes. Keep in mind that Prestone 50/50 boils at 276F degrees, and it boils before it boils over & this creates little bubbles in the jackets which makes "hot spots", Evans doesnt have any evaporative properties. Just thought this might help.
www.evanscooling.com
Old 02-21-2007, 01:06 PM
GMP's Avatar
GMP GMP is offline
Thumbs up
EVANS is the stuff to use.
Old 02-22-2007, 11:49 AM
jeffd jeffd is offline
I have read you can go with a lower pressure cap when using EVANS. Given that, the need to switch to the higher pressure ktm cap is removed if you switch to Evans Coolant.
Old 02-22-2007, 04:45 PM
Eric K Eric K is offline
I use the Evans coolant. It works very well, with no boil over issues even under the most demanding conditions. A few key things with the Evans coolant...
1) get all of the water out of the system before you use it.
2) allow room for expansion - do not fill the cooling system too high
I back the radiator cap off a bit to run at a lower system pressure.
Regarding DEX cool or any other coolant, NEVER mix different colored coolants in even small quantities as some of the combinations are very corrosive to aluminum.
Eric K
'06 GasGas EC300
'01 GasGas XC300
M/C related...very cool CNC work Rick General Discussions & Announcements 3 01-29-2010 06:58 AM
This cool bike 101racing General Discussions & Announcements 3 12-12-2009 04:03 AM
Cool 2t blog PEB General Discussions & Announcements 1 12-08-2009 07:14 PM
Cool Gas Gas stuff, just not for us. gasgasman Enduro Product Announcements 12 09-14-2007 11:14 AM
Very Cool Video Boomhauer Pictures & Videos 1 06-05-2007 07:07 AM
