clutch basket mod
i tore my basket apart and found 2 rivets missing... so i removed all the rivets, and am hoping to tap the basket and run the bolts in from the backside. or do i tap the thin plate and run flat sockets/ovals in from the inside of the basket (seems awfully thin, don't know if bolts will let go...)? is there clearance issues with the button heads hitting kicker intermediate gear underload? (there's aprrox. 3mm clearance between button heads and intermediate gear static, not sure if there's any 'wobble/deflection under load...'
anyone done this??? Last edited by stainlesscycle; 12-11-2009 at 08:32 AM. |
welp, i tapped the basket and ran some m5 buttons in it. we'll see how it works.
works fine for my zip around the yard. ohh and you know that sound that you think is your pv? and it only happens when you lug the motor? well in my case it was the basket rattling around from loose rivets on the clutch cush drive.. noise gone. nice.
im glad you got it together,i did this mod to my clutch a year ago and havent had any issues
clutch basket mod
what length was your m5s
i can't rememember the length now, sorry. 5x14 or so i'm guessing.
Thread Tools | |
Display Modes | |
Clutch Basket Crossover | eff | Enduro Engine - 2 stroke | 13 | 03-07-2010 07:37 PM |
Clutch Basket | jriley43 | Enduro Engine - 2 stroke | 2 | 03-10-2009 02:12 PM |
125 clutch basket | GasGas | Enduro Engine - 2 stroke | 1 | 09-08-2008 10:46 PM |
