Interchangable rocker arm
Hi,
Hope someone can help! I recently acquired a 200 ec '06 model and have discovered that the Rocker Arm where the shock mounts to is total destroyed, any bushing/bearings that was in there are all in pieces and this has caused the hole in the rocker to become ovel in shape. I don't hold much hope trying to get this repaired... I was wondering if this http://cgi.ebay.co.uk/Gas-Gas-EC-125...item1c15ad677c would fit? I searched the gas gas es site and can't even find a manual for a 125 ec 2000 model. The Linkage repair kits you can get cover both these models with the same set so surely they must be the same? thanks |
I don't know if they are all the same but I do have an extra rocker that will fit the older bikes. Where are you located?
They should all be the same. 125 has 1mm longer pull rods, thats all.
Thanks for your replies! This is good news.. I live in the UK so would probably cost a small fortune to post, but thanks anyway much appreciated
Rebore the rocker arm and press in a steel bushing. I did that on mine and it works great..
Henrik Schmidt Faster, Faster!! Until the Thrill of Speed, Overcomes the Fear of Death.. Team YamaGas Racing. http://bricksite.com/teamyamagasracing |
Thread Tools | |
Display Modes | |
How many O rings on the rear suspension rocker | stay_upright | Enduro Suspension | 7 | 01-15-2008 08:58 AM |
