Old 03-31-2011, 02:04 PM
jdosher jdosher is offline
Question Clutch springs
Does anyone know of clutch springs that have a lower spring constant (or are shorter) than the stock Gas Gas clutch springs? Possibly 06 YZ250F?
I've recently put a Revloc Dyna Ring into my 09 EC300. Part of the dyna ring install is to add a number of shims/thrust washers on top of the needle plate to push the pressure plate out and create a gap. All told, the springs get compressed about 2mm from stock, and this has caused the clutch to lose its nice, light pull.
-Jesse
springs Gasgasogeros Enduro Suspension 9 01-04-2010 06:14 AM
What springs should I use? 2 strokes 4 life Enduro Suspension 11 03-21-2009 09:22 PM
