Old 01-08-2021, 10:31 AM
steliost's Avatar
steliost steliost is offline
Just checked it and it seems to open and close fully. i pulled the exhaust out and right side PV cover, looked in the port and the flap doesn't protrude with the valve open. good job.
thanks Jim and Zman.
Old 10-24-2023, 08:11 PM
CrankyBrit CrankyBrit is offline
Unhappy Ahhgggh!!
After reading this thread and figured I should check my powervalve so I can not worry about it. Well now I'm worried about it.
I made a video of my concerns as it seemed easier to explain:
https://photos.app.goo.gl/AymiQUopdweLWA4T7
...and a picture...
My understanding is that the bottom right corner of the "triangle" is supposed to rest against the bolt head on the right ("stopper bolt" in the picture), and then turn clockwise from there as the revs increase.
If I am correct then something is very wrong as the triangle doesn't touch the bolt head it passes in front of it.
Can anyone confirm that my bolt is wrong? It's a regular hex bolt, not an allen one like everyone else seems to have, so the head is probably too slim.
Also the rod that comes up through the hole at the bottom seems to be rubbing against the side of the hole.
Lastly, where is the lock nut that needs heating??
2001 Gas Gas EC250 (or 300?)
2006 KTM 950 Adventure S
1985 Hobie Cat 16'
Old 11-01-2023, 07:03 PM
Well I went ahead and changed the bolt and I'm not entirely sure that the triangle part was actually seated on the end of the rod it goes on.
That's put together better now, but I still can't get it running right.
...going to try a pressure test.
1985 Hobie Cat 16'
Thread Tools
Display Modes
Low down / tickover issue HELP stevehipkiss Enduro Intake/Carburetion - 2 stroke 9 02-14-2011 09:03 AM
jetting - idle issue. stainlesscycle Enduro Intake/Carburetion - 2 stroke 7 12-30-2009 02:47 AM
clutch issue boostedte37 General Discussions & Announcements 2 11-09-2009 06:58 PM
ec 400 gearbox issue Paul Somerville Enduro Engine 4 stroke (including EFI & Exhaust) 3 09-05-2009 10:17 AM
PowerValve Issue- Take A look at this Picture alexpp Enduro Engine - 2 stroke 13 04-12-2009 12:13 AM
