How to tell if Head mod has already been done?
Anyone know if there is a way to tell if the RB head mod has been done on a head by looking at it? measurement?
Thanks |
Calculate the trapped volume
Measure the squish CC the combustion chamber |
Here is some more info.
http://www.gasgasrider.org/html/measuring_squish.html Measuring the squish is probably the easiest place to start |
Thanks, Guess I'll have to pop the head and measure it.
Easy way is the squish. If it says ~2mm then it hasn't been touched. If its 1mm then it likely has.
If you pop it & there is the black anodising all over then it hasn't been touched. If it has been modified you can't tell who by, but have a check of some of the old threads & they'll give you a clue as to what they look like when done. this is my thread, first pica are skimmed but they look black all over the inside to start with. http://www.gasgasrider.org/forum/showthread.php?t=16560 |
