Old 01-11-2014, 01:58 AM
matanp83 matanp83 is offline
Default dilema of buying a used bike...help please
hello guys, im looking to buy a used 2012-2013 2t ec, 125 or 250...
can you tell me please wich one of the above would you recomend more...and in general...are those models relaiable or not? what sords of problems should i look for on the bike before i buy?
the purpes is not hard riding....more of weekends fun riding....littlle technical parts...and a few jumps here and there.
thanks ever so much to the responders
Old 01-11-2014, 02:29 AM
Simmo737's Avatar
Simmo737 Simmo737 is offline
Two strokes are much easier to not be finance destroying, but the motor is not where you will get hurt. At some stage you will need to do a piston change that any mechanically enclinef person can do. The internet is full of tips on the following, do some research. Watch for:
Cracked rims, broken spokes especially at the rim ( worn wheel bearings are an easy fix)
Pitted, scratched on dented chrome fork sliders, or bent forks.
Twisted triple clamps, worn steering stem bearings.
Cracked or twisted frame (especially near foot pegs), worn frame rails on bottom.
Chain wear on frame, swing arm or engine case. Seized swing arm chain adjusters
Leaking or cracked fuel tank
Leaking shock
Everything else is pretty well hard to detect or easy to fix or a "consumable"'As for capacity, a 125 is harder to ride than a 250, as the spread of power is smaller and therefore requires many more gear changes and a lot more momentum to carry you through obstacles (ie you need to ride it faster) and is therefore harder physically unless you really no what your doing. Just my 5 cents, hope it helps!
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 01-11-2014, 02:58 PM
bukwheat's Avatar
bukwheat bukwheat is offline
I would definitely lean toward the 250. A 125, like Simmo said, requires some definite clutch work and also depending on your weight, may be rather underpowered if you're over 180 lbs. The fun factor may wane on a 125 in a steep hill scenario. Also a 125 will probably have been ridden harder and require a top end sooner than a 250.
Alan
14GasGas ec300r
Old 01-11-2014, 04:36 PM
iajim iajim is offline
Just my opinion- get a 250, you'll be able to tailor the power and suspension to your liking. Fast/ slow/inbetween- you'll be able to make the 250 work. On a 125 everything is going to be high rpm, you can modify them all you want but there will still be an all or nothing aspect to the power. Let us know what you get, if there's anyplace that knows GG inside out, it's this forum!
Old 01-11-2014, 08:09 PM
Banned
Don't dismiss a 300. A 300 can be lugged and short shifted off the pipe and still have torque to move you over obstacles.
Old 01-12-2014, 08:04 AM
Coop's Avatar
Coop Coop is offline
I can't believe you've gotten so many responses and not one person asked your size or skill level yet. That will really decide if you want a 125 or 250 in my opinion.
-Mike
2009 Beta Evo 300 4T - 1982 Suzuki PE175
Old 01-12-2014, 12:27 PM
twowheels's Avatar
Or where you live or what you ride on ...
Steven Beane #275
afterhourscycle.com
Need help buying a new bike pls brokenheadbrad General Discussions & Announcements 57 09-18-2012 06:58 AM
Buying a bike out of state and registering in CA? 1150A Western United States 8 11-13-2011 06:01 PM
to valve or not to valve.... that is the dilema. dank Enduro Suspension 19 05-06-2010 07:41 PM
Buying Gas Gas 250 Enduro250 General Discussions & Announcements 3 08-28-2008 05:53 PM
buying ltr jet kit moff747 Enduro Intake/Carburetion - 2 stroke 2 06-02-2008 01:06 AM
