Old 08-27-2008, 12:46 PM
Enduro250 Enduro250 is offline
Default Buying Gas Gas 250
Hi
I am in the UK looking for a GAS GAS 250 EC.
I have recently found one that I am interested in, a 2007 EC model but
it seems to have a black exhaust and weird pipe coming from the Bottom of the left hand radiator!!!
I asked dealer and he knew nothing about the pipe and said the black exhaust looked as if came from the factory.
Did the 2007 Gas Gas 250 ever come with a Black pipe.
Have included a picture for reference. Any ideas what the weird pipe may be for, does not look standard?
Old 08-27-2008, 02:04 PM
Nick's Avatar
Nick Nick is offline
Not positive but i would say its a euro emission spec bike with a catalyst in the exhaust.
Old 08-27-2008, 02:55 PM
"euro emission spec bike with a catalyst in the exhaust"
If it was this spec, would there be any other differences apart from the Cat in the exhaust?
Is there any Engine, Frame or other differences?
Thanks,
Sean
Old 08-28-2008, 05:53 PM
cladoo's Avatar
cladoo cladoo is offline
There was also a plug replacing the left side power valve, you should check that(it is black and the real one is silver). The catalyst is easy to remove as long as you can weld. It is right at the joint after the first u bend coming from the engine. If you look at the pipe closely you can see where the pipe was rewelded. Cut around the pipe and pull out the catalyst. you have to cut off the small pipe and plug the hole up with weld. There is also a throttle stop under the carb cap, remove that. Check the jetting as the euro emission spec used a 9 slide and a 115 or 119 main jet. You need a 7 or 8 slide and about a 175-180 main jet.
I will try to show some pics about the pipe.
Claude
2019 XC300
2010 Nambotin 300 sold
'07 EC300 sold
'06 EC300 sold
'78 Suzuki RM250C2
'75 Yamaha YZ250B sold
Buying needles biggstr6 General Discussions & Announcements 0 07-08-2010 08:17 AM
Buying my first Gas Gas TorbenS40 General Discussions & Announcements 3 03-31-2010 07:00 AM
New member buying a gas gas halley 450 speeddemon General Discussions & Announcements 5 10-12-2009 03:35 PM
buying ltr jet kit moff747 Enduro Intake/Carburetion - 2 stroke 2 06-02-2008 01:06 AM
