200 jetting with NOZI?
Trying to get the new 200 dialed in, ironically it came with a different slide than my 200?
Anyway, the bike came from CO and was lean, so I made these initial changes: 175 main 42 pilot NOZI #2 A/S 1.5 turns ASII 38mm carb (I think...has the screw top...how do you tell anyway?) Bike starts easily, a little sluggish off idle and burbles through 3/4 throttle. It also came with a CHN needle - haven't looked into the specs on that yet. Not being familiar with the NOZI, any input on swapping to something else? I was going to go with the same as mine, but don't know because of the slide difference. I'll probably throw a 40 pilot in at some point, unless I can just change the needle. Any input greatly appreciated. |
CHN is for emissions control on a well restricted engine. Won't work, and not even worth trying. Its stupid lean.
What jetting are you running in your bike? |
I have the following:
172 main 40 pilot A/S 1.5 R1470 #2 7 slide Bike runs perfectly, still have drool, but plug is the perfect color. |
Try your jetting (inc your slide) and see how it runs. Nice quick test.
What is your slide and what is his? The NOZx is the half clip variance to the N1Ex that comes stock with everything else. The I is the same diameter as a W. |
My 200 has a #7 slide, this 200 has a #6 slide. The original owner might have swapped it out; surprised at the difference as they're both '11 EC200 Six Days. Anyway, I'm hoping to avoid spending the chunk of change on the slide. Any suggestions on needles given the #6 slide? |
No hands on experience with the 200's so bit hard to recommend a starting point. Richer slide will likely just req a bit leaner diameter/pilot.
Jetting ? | rootsnrocks | Enduro Intake/Carburetion - 2 stroke | 38 | 03-12-2013 02:22 AM |
jetting help | BryanMcc | Enduro Engine - 2 stroke | 8 | 07-26-2012 11:45 PM |
jetting help for 05 300 please... | mackmack | Enduro Intake/Carburetion - 2 stroke | 5 | 09-03-2007 05:10 PM |
06 300 jetting | fury1 | Enduro Intake/Carburetion - 2 stroke | 1 | 07-31-2007 06:37 AM |
02 ec 250 jetting help | crem55 | Enduro Intake/Carburetion - 2 stroke | 9 | 07-12-2007 01:44 PM |
