Old 08-27-2007, 06:44 AM
mackmack mackmack is offline
Default jetting help for 05 300 please...
BIKE is 100% stock 05 300 DE runs great in moring temps in the 60's with low humidity..
However in the afternoon temps are reaching 95-97 with high humidity.. 1000-2000 feet.. Bike barely runs, "burbbly" everywhere except wide open..
Do i need a smaller pilot and lean out the clip???
Old 08-27-2007, 08:22 AM
gasIdaho gasIdaho is offline
I'd try the needle first. Quick and easy
Old 08-30-2007, 08:21 PM
gasit16 gasit16 is offline
Default jetting
my 300 runs good except at top end it breaks up is it to rich on the main jet
Old 08-31-2007, 12:21 PM
You could be too rich on the main. Do a plug chop test. I would check the powervalve operation as well. I had a similar issue only to discover my PV wasn't opening all the way when approaching open throttle. It would start bogging/cutting-out
Old 08-31-2007, 06:29 PM
Default jets
thanks i will try that tomorow and see what happens
Old 09-03-2007, 05:10 PM
BTW...I would highly recommend doing the RB Designs carb mod. It will save you many hours of jetting frustrations. The 300's seem harder to dial in even with the LTR kit. This mod will encompass jetting, needle, slide mod, etc. One stop shopping.
where to go from here. jetting q. dank Enduro Intake/Carburetion - 2 stroke 105 04-11-2011 04:25 PM
LTR or JD Jetting Kit Elvis74 Enduro Intake/Carburetion - 2 stroke 7 04-08-2010 02:49 PM
04 ec 300 Jetting lordfeyr Enduro Intake/Carburetion - 2 stroke 12 01-26-2010 03:16 AM
Need help jetting an 06 EC 250 piperpilot12w Enduro Intake/Carburetion - 2 stroke 3 11-16-2008 11:19 PM
06 300 jetting fury1 Enduro Intake/Carburetion - 2 stroke 1 07-31-2007 06:37 AM
