Stock Ohlins 888 Clickers
Hi everyone.
Just curious as to what settings people are using with stock valving. If you could follow the format below would be great. I'll post mine after I count my rebound again. Can't remember where its at. Weight (geared up): ~85kg LSC: 19 out HSC: 1 3/4 out RBND: <to enter> out (~20) Free sag: 35mm Race sag: 115mm Spring: stock Terrain: Mixed. But mostly 2nd 3rd 4th rocks and roots. Creek beds etc. / single track. Last edited by Jakobi; 12-06-2011 at 02:58 AM. |
11' Six Days 250
210# A-vet H/S LSC= 28 out HS= 2 turns out RB= 12 out Free Sag= 27 Race Sag= 105 Stock Rear spring Terrain= mixed 1st-4th gear, rocks, roots, stream beds. Single track and grass tracks. |
28 out, that's full soft?
30 out is full soft. 28 is where I like it and I haven't bottomed it out hard yet, and some of the H/S tracks have had huge jumps eg Broome Tioga Mx track.
I'm not sure if the Six Day's models had different valving from the std model or not, but I could not get the front forks to stroke through the last 2" of travel no matter fast or hard I hit stuff they simply would not go through that last 2". I've since had them revalved by W.E.R and they now work great as does the stock valved shock. |
I haven't played with the shock too much and am quite happy where it is. I may back it out some more just to see based on your settings. I have found my forks rarely use 100% of the travel. I haven't come right out on the clickers yet. |
Stock Spring Rate in '11 Ohlins Shock? | bputt | Enduro Suspension | 2 | 01-13-2011 01:47 PM |
sachs clickers | armyoforange | Enduro Suspension | 1 | 02-16-2008 08:42 PM |
03 ec 200 stock settings? | Airborne | Enduro Intake/Carburetion - 2 stroke | 0 | 06-24-2007 07:45 AM |
Base clickers for Sachs shock (07)? | Dylan Bod | Enduro Suspension | 1 | 04-19-2007 12:28 AM |
