adding a battery for HID
Im about to make a new loom for my 2000 EC 300 as the one on there is abit rough and repair after repair, if i wanted to add HID i know id need a battery so isit hard to wire in a battery? would i need to change the stator? im not sure which stator i have but i remember seeing something that you can tell by the postion of the wire as they come out of the case? mine comes ou at the 2 oclock postion
Then you have the larger 2K-3 ignition. For HID you will need rectifier/regulator for DC system with isolated grounds.
what is isolated grounds??
Please do a search here on "floating stator", "floating grounds", and "DC conversion". I have gone into detail several times.
There was a lot of information in this thread.
http://www.gasgasrider.org/forum/showthread.php?t=1859 Helped me when I converted mine a few years ago. Jeff |
thanks alot.
Thread Tools | |
Display Modes | |
Can someone help me with a adding a headlight to a 99 EC300? Need electrical help. | flatout111 | Enduro Electrical & Wiring | 6 | 11-28-2012 09:38 AM |
12 battery box | shark4465 | Enduro Chassis & Body | 2 | 11-09-2012 04:45 AM |
Battery for a 07 450? | fastisbetter | Enduro Electrical & Wiring | 2 | 03-29-2011 08:06 PM |
2k-3 Swap and adding headlight | Brian | Enduro Electrical & Wiring | 28 | 10-21-2010 11:29 AM |
Adding another gasser to my stable | joey11 | General Discussions & Announcements | 0 | 05-15-2008 12:11 PM |
