Old 04-17-2014, 05:26 AM
Default 2013 ec250r
Modified head. 1.2mm Squish 13.1:1UCCR. BP Ultimate 98RON w/ Amsoil Dominator at 50:1. Far Northern Conditions (20-30C, 50+%RH). ASII 38mm Carb, #7 slide.
I've now put a bit of time in on the new bike, and strangely, even though the old 2010 has a very similarly setup engine (head work, carb, etc) they jet very differently. The carb on the new bike has an additional jet in the bottom of it. Perhaps a leak jet?
The new engine feels richer for a given setting. I'm wondering if changing carbs between bikes will identify where the differences are.
2010 model is running 40 N3CW#3 178, and runs with zero spooge, a little smoke, and a little fat at light loads. It NEVER loads up, and always takes revs cleanly through to WOT.
The same jetting on the 2013 runs richer over all. The pilot is very similar in its effect on idle and off idle response. On the needle though, its much richer in the 1/4 throttle range and doesnt respond as well. It will load up when initially started and takes time to clear out. Spooge is massive. Dropping to a 175 main showed little improvement. Moving a half a clip leaner (N3EW#2) was crisp and performed better but I believe gave up some mid throttle grunt. Also hard to test due to the day being particularly wet! Historically the N3 series needles to tend to be more binary (on/off) than some other choices.
Changing to 40 NEDW#2 172 showed some improvement in throttle response, less loading up, and a very smooth linear spread of power. Still spooged substantially, however much less blubber, still grunts down well, and has a super strong mid to top.
Changed to 40 N3CW#3 172, still blubbery off the bottom, did not ride it hard enough to test the mid, but would be same as previous, and whacking the throttle open hard (on the stand) caused a lean hesitation on the main. Obviously way too lean towards WOT as is expected with this needle.
So over all, I'm not sure if I should stick with the 40 N3EW#2 178, or the 40 NEDW#2 172. I think for now I'll save changing the brass and put some more time on the Suzi needle.
Old 04-17-2014, 07:45 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
i agree. my bike is running leaner than the 11, im about to go back to a 38 pilot, i thought it was overheating due to an off idle lean condition but it was motul transoil expert gear oil - too good for a gas gas clutch, i've changed to the dirtbikeworld oil of choice penrite hpr gas 10 (10w50 universal style semi synth - probably like rotella t in the US) and it is like magic, lever feel has gone to completely progressive with no nasty grab point and the bike is quieter, can still kick in gear and no heat issue.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 04-17-2014, 08:08 PM
I hear you Simmo! I just dropped the NEDW#2 back in this morning and went for a scoot around a near by area to test a few things. With the 40 pilot and 172 main I can run the Air Screw out as far as 2.5 turns before it starts to show a lack in torque so I too could probably drop to a 38, which is quite strange on a 250. I'll run it at 2 turns and see how it runs. Bike was a real pain to start after yesterdays quick ride on the N3CW#3. Must have left the plug somewhat loaded up.
I'd love to work out how to get rid of the spooge! I think the packing is soaked to maximum capacity!
In regards to the 40 NEDW#2 172 the bike is an animal. So smooth in terms of roll on and part throttle. A little blubber on the bottom which is quite acceptable and gives good response and grunt. Top end pulls strong. The biggest thing I notice is how well the engine responds to the clutch. So easy to bring it on song with a huge amount of power from almost anywhere in the rev range. It Launches!
Thread Tools
Display Modes
2013 ec250r Jakobi Enduro Product Reviews 163 02-21-2016 03:52 AM
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
2010 EC250R - Aussie Rox Jakobi Pictures & Videos 2 06-24-2012 04:50 AM
