Old 12-02-2013, 03:13 AM
Default 2013 ec250r
I took ownership of this lady the other day!
During PD, we scrapped the stock jetting. It was 42 N1EF#3 175. I don't know how thats expected to work, but went to 42 N3EW#2 178 and she fired up on the second kick. Did I little 20m run and called it done.
Back at home she's been pulled down again and I'm slowly working through getting things set the way I want.
Been greasing bits and pieces (will save linkage and steering stem bearings until suspension service time - 10hrs).
I need to get some rad guards on order, will likely go with Force as they've held up well for me on the 2010. Will also be adding another P3, and running it with the stock bash plate.
Removed the indicators and rear fender number plate holder. Nicely planned here with a drop out panel to access the connections from below. I've packed some foam in where the wires used to exit and also run some tape over the joins to keep the mud out.
All wiring behind the headlight pulled down and cleaned up and zip tied for a nicer fit. Connected up the hill switch for the lighting block. Will run the other one too!
Removed the cross brace on the Renthal Twinwalls - need to purchase a fatty bar pad.
Scrapped the lever mounted choke and installed the plunger.
Air filter needs a reoiling, and a few burrs/casting flaws need to be removed from the sealing surface in the airbox.
Airbox lower joins will be sealed with marine grade black sikaflex. Lower drain has had the slit extented to open easier (and wider).
Compression reading taken on my guage. Its a cheapo that includes the volume of the adapters and tubing and always reads low. Got 140psi where my reduced and corrected S3 head got 145psi (both using a single .5mm base gasket). I have yet to measure the squish.
Chain guard removed.
Thats about all for now, until more parts arrive. Then I'll think about riding it.
Still haven't decided if I want to pull the head before I break it in or after, and I still have to go over the suspension and measure up the sag figures. I'm thinking I'll probably go straight to a 5.4 rate rear spring which I have on hand if the 5.2 doesn't get the numbers I'm after. Dave at Suspension matters specced up a set of fork springs on a 300R not long ago and they came in at .44 which doesn't sound too far off.
Old 12-02-2013, 04:13 AM
john r b's Avatar
john r b john r b is offline
Wink
Very nice, kick or button?
Old 12-02-2013, 04:20 AM
No button. Race model, kick only. Have noticed the kick starter occassionally does its thing where it doesn't engage as well as it should. Looks like I'll be in stretching the spring at first service too.
Anyone with the later models had to do much in relation to the powervalve? Preload, shims, etc. I also have a 8mm spacer I can install to give some more volume on the LHS cover, which is the newer style one (not the finned style). I think I'll ride it before I change that up though.
Old 12-02-2013, 06:28 AM
hamilton's Avatar
hamilton hamilton is offline
Nice, think you will really like it. Waiting to hear a ride report when you get it sorted.
15 GASGAS EC 250
19 Sherco SE 125R
Old 12-02-2013, 09:10 AM
Fred1956's Avatar
Fred1956 Fred1956 is offline
Look at you Jake! Nice!
Fred Overstreet
2010 EC250 SixDays
2006 GasGas TXT 280 Pro
Old 12-02-2013, 09:54 AM
nambo-trev's Avatar
Nice pick up!
trevor
Old 12-02-2013, 10:41 AM
adv rider's Avatar
adv rider adv rider is offline
Default new bike
Nice! That will be a big help for me, since I know you won't be able to leave it alone.
2012 xc300 - Great bike! sold looking for 18+
Old 12-02-2013, 11:59 AM
Vindicator Vindicator is offline
Congrats Jakobi, the 13' is quite nice and kicked out some of the gremlins of past models . Don't forget the ride report
Vindicator
'11 EC 300R
Old 12-02-2013, 12:31 PM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
Lucky man..........VERY nice.
Ride safe and enjoy
Regards Shuv - 2006 EC 250
Old 12-02-2013, 01:16 PM
Diggs345's Avatar
Diggs345 Diggs345 is offline
Good to see you stuck with gas gas jake , nice ride
2011 Gas Gas EC250R EricW835 Used Bikes 3 10-20-2013 10:58 AM
EC200R vs EC250R (2012 model) Jakobi General Discussions & Announcements 30 02-11-2013 03:41 PM
2010 EC250R - Aussie Rox Jakobi Pictures & Videos 2 06-24-2012 04:50 AM
