18 EC300 Battery not charging FIXED
**Regulator/Rectifier is putting out DC voltage...rising & falling w/throttle
**Relay functioning correctly **Motor & starter running perfectly **Battery..new AntiGravity 8 cell small case..... runs down after each ride...I sometimes have to kick start. Last ride battery was at 8.6 volts at end of ride. Possible causes yet to be verified: #1 Diode at relay - Below is a quote from an old thread indicating it could be the diode attached to the relay. #2 Loose/faulty connection - I have traced most connections but could have missed something. Quote:
Thanks everyone!! Last edited by Tech; 09-08-2023 at 03:04 PM. Reason: solution to problem |
Have not tested the diode. Not sure how to do this.
I have a Fluke 88V meter. Also, I am having trouble reading the wiring schematic. I do not understand how the Battery/Relay/Starter schematic interfaces with the rest of the wiring schematic. |
Diode Test Video
Caution I saw this video on youtube about testing diodes but I don't know anything about this process, so be careful and use at your own risk.
https://www.youtube.com/watch?v=9LwDPHvzH90
2011 GG EC 300E, 1994 CR 250R, 1984 RM 250 E, 2022 Ranger 300 "If you stop eating donuts you will live 3 years longer. It's just 3 more years that you want a donut." ―Comedian Lewis Black "I think best when I have a wrench in my hands." Soichiro Honda "Dreams are messages from the deep." -Unknown Sardaukar |
PM Member Neil E
PM Member Neil E, he is the electrical guru on this board.
More testing @ diode....view "J" on wiring schematic
**Varying DC voltage on Red wire while bike is running..14.3 max **Static DC voltage on Red/Yellow wire while bike is running & not running. Same voltage as + - on battery. **No readings on White/Black or Green/Yellow wires while bike is running or not running |
Thread Tools | |
Display Modes | |
'18 EC300 (battery not charging) | TerraMoto | Enduro Electrical & Wiring | 12 | 07-17-2020 10:03 PM |
2018 EC300 Speedo Battery Code | malin | Enduro Electrical & Wiring | 1 | 07-31-2018 03:31 PM |
not charging battery | OLD.IT | Enduro Electrical & Wiring | 2 | 06-21-2015 03:01 AM |
Charging phone on 2011 EC300 | Quigs | Enduro Electrical & Wiring | 9 | 03-07-2015 12:55 AM |
Battery Not Charging | GLantern | Enduro Electrical & Wiring | 6 | 08-25-2013 03:45 PM |
