Old 01-01-2015, 08:27 AM
Quigs Quigs is offline
Default Charging phone on 2011 EC300
Im wondering if and how i can wire up a charger for my phone.
Im planning on using my Samsung S4 as a tracker but the battery will not last long enough. is there a way i can connect a charge lead to the bike.
I have a car charger i could adapt to wire up but not sure if it will work as not great with electrics, i dont know if it will be suppling to many amps etc.
Thanks in advanced.
Old 01-01-2015, 09:16 AM
Get on eBay and buy a 10,000mah battery pack for your phone. Problem solved. Wiring a charger into your bike is more trouble than it's worth unless it's an e-start then it would be easy but now you will have a cord flopping around and eventually it will mess up the charging port in your phone
Old 01-01-2015, 09:17 AM
OR!! Buy a trail tech voyager. That's what I did best $200 I ever spent
Old 01-01-2015, 09:36 AM
Kendog Kendog is offline
You can get a handlebar mounted 12v usb socket or lighter socket that's water proof And just get yourself a decent charger lead
Socket has it's own wiring loom with built in fuse you just wire straight onto battery
I used this in my old yamaha dtr with iPhone 5 worked a treat
Ken
Old 01-01-2015, 09:44 AM
Thanks for the info guys.
I forgot to mention mine is not the e-strat model so i have no battery.
Old 01-01-2015, 12:51 PM
gasgasman's Avatar
You will need to have a dc voltage source to charge your phone.
Old 01-02-2015, 03:11 AM
Would something like this be sufficient to last the day?http://pages.ebay.com/link/?nav=item...796607&alt=web
Old 01-02-2015, 03:45 AM
Yes something like that would do but if I was you I would look at the more powerful units. I've got a case on my iphone that's 18000 and it won't fully charge my phone and in sure if you are using your phone for gps you will use some power
Try the 50000MaH chargers there only ?5-?10 more
Ken
Old 01-02-2015, 03:48 AM
http://pages.ebay.com/link/?nav=item...d=261549864811
Old 03-07-2015, 12:55 AM
liamthom's Avatar
liamthom liamthom is offline
assuming you have a estart model would a 12v to 5v 3a step down work? to my limited knowledge the phone will only pull what it needs. and phones use 5v and 1-2A.
also you would just hook it up to the battery directly. the bike should charge it
not charging battery OLD.IT Enduro Electrical & Wiring 2 06-21-2015 03:01 AM
Battery Not Charging GLantern Enduro Electrical & Wiring 6 08-25-2013 03:45 PM
2011 EC250 graphics fit 2011 EC300? Jarvo_325 Enduro Chassis & Body 2 11-25-2012 06:28 PM
Just got off the phone with jd jetting. Guess what Colemanian Enduro Intake/Carburetion - 2 stroke 10 11-23-2012 02:20 PM
