Broke my Big Toe!!! front Brakes went out..
So my 2010 ec 250 and I were doing the practice laps here in Dallas, pinned 3rd in the rocks toward a rocky 90 degree turn grabbed the front and mushy nothing... Back brakes locked and I slide turned high ended broke toe!! HOW I broke my my big toe my boots I still do not know.. I did get a few free air miles and a helmet rocky landing!
Before I left the house I saw a small Oil puddle ( very small about a dime ) on my garage floor. first thing was darn fork Seals.. Ok its not bad Ill do those when I get home.. WRONG that was brake fluid leaking out of the bottom Bolt of my resevoir !!! Now pit testing I didn't really notice as it was just felt smushy and I figured I needed to heat up the brakes.. OK, here is the first 30 minutes huge down hills scared to death practice lap ever... SO I get back and start looking at the brakes and see I have a leak from that round bubble bolt area and I have no idea why.. Then it hits my I had moved my brake lever as FAR forward and down as possible so I could stand up more.. Apparently I had but that bolt in a bind and it leaked so I have a few questions... 1. Is there a better bolt or something?? I can not believe a small bit of contact created a bind that caused a leak!! However thats exactly what happened.. 2. My Rotors also had grease on them of some sort and Honestly The only thing I spray my bike with is WD40 on everything after a bath.. I have yet to get my brakes back to a suitable stopping power and I have cleaned that rotor 10 times.. Could the pads have soaked something up? The lever feels firm, but no stoppie just a slow slowdown.. 3. Is there a better gas cap lid??? I sheared mine apart in the wreck 4. I never realized how much I used both brakes till one was gone!! |
Pads will soak anything you give them, it's a matter of evaporation. With WD-40 I would assume that the oil would stay in the pads, therefore you need new pads. The rotor is steel, it's not going to absorb much oil. I expect the greasy feeling you found is the WD-40 being reapplied to the rotors as you heat up the brakes (when they work...).
Regarding the banjo bolt, is it possible that the bolt loosened up when you rotated the master, therefore causing the leak? For good measure I would replace the banjo bolt and crush washers, just for insurance. Sorry to hear about your wreck and toe, glad that you didn't get a chopper or flashy box ride.
Phil (New bike pending...) |
Sorry to hear about the mishap. Lucky its just a toe, and hope it heals up well.
I'd start with fresh pads both ends. Fresh fluids both ends. Get yourself a 100cc syrings and some clear 5-6mm tubing. Another smaller syringe to draw the used fluid back out of the master cylinders. Then reverse bleed them well. Prior to doing this I'd also pull the banjo bolt and replace the brass/copper crush washer. Make sure it seals well and torque it up. As to why it initially leaked is anyones guess. I'd say unrelated to you moving the lever forward though. Probably more likely that it has vibed itself undone a bit over time. |
Thanks Guys!!
Any place I can get a replacement fuel cap?? Preferably not plastic? |
Someone makes a billet one but I remember them costing about 4 times more than a fuel cap should. Just get onto your local dealer and get a replacement cap. I have a brand new in the wrapper genuine gg fuel cap sitting in my spares kit.
Ouch! I broke my left big toe, twice and the right one once, within the last 7 months. The only real upside to a broken toe...Once your foot swells a bit, it sorta goes numb, so you can keep riding. It does hurt like h*#l until that happens. I no longer let my feet stray, from the pegs.
All healed up, and ready to burn some fat. |
S3 makes the gas cap, I have one, not sure it seals fully either!
2011 EC300 2013 TXT300 Factory Replica 2014 Polaris Assault 2004 Snowhawk 600H.O. |
don't know if anyone has ever tried to reinforce those flimsy necks on the fueltank? |
and then this thing broke.... | dank | Enduro Intake/Carburetion - 2 stroke | 2 | 03-21-2010 05:18 PM |
Did I broke something in that picture? | GasTimppa | Pictures & Videos | 7 | 02-20-2010 03:46 AM |
Front brakes driving me nuts | brains | Enduro Chassis & Body | 11 | 07-03-2009 03:49 PM |
Grabby front brakes | rpduc | Enduro Chassis & Body | 11 | 05-28-2009 08:39 AM |
Broke the new 08 in on Saturday | REVERUP | General Discussions & Announcements | 1 | 04-07-2008 11:05 PM |
