Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Used Bikes
Used Bikes Used Bikes For Sale - No Part Outs
Old 07-23-2013, 04:29 AM
yourmatedave yourmatedave is offline
Default 2002 EC250 ?1500 ono UK
V5 in my name
3 previous owners, including the dealer I bought it from who registered it, so technically only 2. I believe the bike has been stored/unused for a while, and generally used very little.
2002 EC250X. I also have a set of off road wheels with almost new road legal tyres. The front is an excel with a talon hub, and the rear is standard. I have the nissin caliper for the 260 front disc, but you will need a different caliper bracket to mount it.
Mot 2014 May
Tax 2014 April
Pilot sport tires. Rear is getting low, front is somewhat better.
Messico header pipe, 1 small dent
Boysen reeds
Just had new twin air filter, plug, pipe o rings, though it still weeps a little oil from the header gasket.
renthal fat bars, nearly new grips
brembo front caliper and floating disc
Marzocchi shivers 45mm stanchions
Ohlins rear shock
Decent chain and sprockets, 80-90% Rear is a 41 off the top of my head
The headlight, tail light, horn and indicators all work.
When I had the pipe off the piston looks absolutely fine, as does the bore.
I have just changed the gear oil and the coolant to spec.
Please note there is no speedo but the original lap counter, which I am unsure if working, the lights for indicators and headlight works fine.
ALL the bearings are fine. As are the brake pads.
Fork seals are fine and the stanchions are spotless.
Bad bits!
The rear brake pedal switch for the light has broken off, so the light does not work from the pedal.
Bit of oil leaking from the header gasket after an hour or so riding, not the o rings on the pipe spigot as these have been replaced
There is some clutch drag when the engine is not running. May need back bleeding.
There are a few tiny spots of rust on the frame from storage, most of which simply rub off, they never bothered me. There are 1 or 2 of the plastic inserts for the front fairing panel self tapping screws broken off from the holes, these are replaced easily and very cheaply. This is not a new bike, there are some scratches and marks. That's all I can think off. I have probably only ridden the bike 10 times. Any questions please ask. Cash on collection from Cranleigh many thanks
http://postimg.org/image/a1gfd3s6j/
http://s9.postimg.org/p2k3glctr/DSC_1332.jpg
Old 07-30-2013, 03:15 PM
Subbs Subbs is offline
is that 1500 euros or gbp u mean? so i can calculate to my countrys vaule. dont have a clue what it would cost to ship or so but if thats not to expensive and maybe can discuss the price abit more?
Mike
Old 08-24-2013, 11:04 AM
ohffs's Avatar
ohffs ohffs is offline
still available?
gas gas virgin
HTML code is On
My new bike! EC250 2002 yourmatedave General Discussions & Announcements 12 05-23-2013 10:55 PM
Hypothetical Q - KTM or Gas Gas+$1500 Jeffro General Discussions & Announcements 18 12-21-2007 12:01 AM
