Old 09-08-2013, 11:42 AM
Moto7man Moto7man is offline
Does Magura make a LHRB system?
―Comedian Lewis Black
-Unknown Sardaukar
Old 09-08-2013, 07:15 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
Originally Posted by HenrikSchmidt View Post
I have to warn you against the new rekluse dual system.
http://rekluse.mybigcommerce.com/yam...model-fitment/
First off all, It's just a overpriced "hope" MTB brake master with a Rekluse logo.
Second, is the worst part, the dual action is optained by changing the lid of the original foot operated master to a new Rekluse lid with a thread to fit the brakeline from the LHRB.
That means when you use the LHRB you pressurize the original master from the top, and the brakefluid reservoir is NOT designed to take that kind of pressure!!
My friend fit the system on his GG 300 and it was actually working good, untill he while braking, heard a loud "POP" and the LHRB lost all pressure and his right boot was soked in brakefluid, the level check window in the foot master was gone leaving him with a big hole in his rear master..
I have heard this exact same thing before.
There is a lot of discussion about it on KTM Talk.
2012 - XC 300 Racing
Seattle, WA
Old 09-09-2013, 06:48 AM
Anders Anders is offline
I have not seen this in the flesh, but...
Of course the rear master cylinder isn't designed to take the brake pressure in its reservoir (window and all), and I do not think the Rekluse design intends to use it that way either. There should be a o-ring at the bottom of the part that you insert into the rear master cylinder. At least this was the case with the previous dual action design (where you used the clutch master for the rear brake). This o-ring seals off the pressure, so that the pressure from the left hand master cylinder is routed into the rear master cylinder's high pressure circuit.
Could it be that the o-ring is missing or leaking, or that the length of the insert is wrong for the actual rear master cylinder?
I have been playing with the idea of building a similar system for my bike, so if you could give me a link to the Hope (or other make) radial master cylinder that Rekluse use, I would be grateful.
Old 09-09-2013, 08:36 AM
Banned
It's actually a "Hayes" lever. Google Hayes trail disc brake. They have several version trail, pro and stroker and you can choose black or white also. I went with a white to be a bit different . Plan is to have a custom braided line and fitting eliminating the rear brake lever(tired of replacing them)
Old 09-09-2013, 09:37 AM
The Rekluse install video does show a rubber oring for fitment on the bottom of the brake reservoir.
-Unknown Sardaukar
Old 09-09-2013, 03:40 PM
HenrikSchmidt's Avatar
HenrikSchmidt HenrikSchmidt is offline
I will take a better look at my friends system, maybe he installed it wrong?
It's a "Hayes" not a "Hope" master, rekluse are using, The Stroker Trail master:
http://www.chainreactioncycles.com/d...l/rp-prod19989
Henrik Schmidt
Faster, Faster!!
Until the Thrill of Speed, Overcomes the Fear of Death..
Team YamaGas Racing.
http://bricksite.com/teamyamagasracing
Old 09-09-2013, 05:36 PM
StuJohnson's Avatar
Good find on the Hayes Mtn Bike master cylinder.
I really like the slim style of this and how it does not take up much space at all.
But my concern is that it will not be able to operate my new LHRB setup that uses a daul piston KTM 950 Brembo Rear Caliper. I am currently using a KTM Brembo Clutch Master Cylinder to operate my caliper. It provides plenty of braking power that only a slight grip of the lever and the brakes are there! I currently still have my Magura clutch installed but it makes for a very messy left side of my handlebars. I honestly don't think I have a need for my clutch but am still keeping it for a safety precaution...
Seattle, WA
Old 09-09-2013, 10:43 PM
StuJohnson's Avatar
To answer your question.
Yes they do. And so does Brembo.
They are made to be used on stunt bikes. But with this type you have to add a small brake fluid reservoir and they are very expensive.
http://www.haibikeshop.com/index.php...03mplilt717gt5
Seattle, WA
Old 09-09-2013, 11:44 PM
Darkside Darkside is offline
rekluse installs an 1/8" spacer to increase the fluid capacity in the Hayes
2006 GasGas EC300 2011 KTM 300XC
Old 09-10-2013, 10:14 AM
I like that caliper! I'll take a look at your link for the Magura master cylinders.
-Unknown Sardaukar
LHRB with standard Clutch lever/cylinder stay_upright Enduro Chassis & Body 5 09-07-2013 05:45 PM
rekluse ??? Moto-x Enduro Engine - 2 stroke 1 03-05-2013 02:54 PM
Rekluse EXP 2.0 for Gas Gas? AZRickD General Discussions & Announcements 13 05-25-2011 06:44 AM
