Old 05-30-2014, 12:26 AM
kyton's Avatar
kyton kyton is offline
If i turn it all the way up then when it gets to the end it makes 2 clicks. Then when when turning it down again only 2 clicks from topand then it is just smooth turning until it reaches the end.
Old 05-30-2014, 09:02 AM
Banned
Needs a service...
Sent from my SGH-T999L using Tapatalk
Old 06-01-2014, 11:46 AM
kyton's Avatar
Put the shock in. Played with the rebound knob all the way up and all the way down. Definitely a difference between the full on and off. Only 4 clocks at end though.
What is the correct torque settings for top and bottom bolt of the shock. 2004 200ec. i used 60 nm for top and 26nm for the bottom as per a table i found on the site. Manual says 39nm, dose not specify top or bottom.
Just tried again now. Compressed the shock a good few times. Turned the rebound to the bottom. Compressed again. Turned until I got a click. Now I have turned it up to 15 clicks. Will check if it will click more
Sent from my GT-I8190 using Tapatalk
Old 06-01-2014, 03:43 PM
Originally Posted by desertgasser300 View Post
Needs a service...
....just incase you missed it
Old 06-01-2014, 11:03 PM
kyton's Avatar
Never missed it.
Problem IDing/Baselining Ohlins Shock GasGasDreamer Enduro Suspension 3 03-31-2015 03:18 PM
07 ec250 will 05 ohlins rear shock fit gasgasandrew Enduro Suspension 1 01-22-2010 04:39 PM
Ohlins Rear Shock oil change and regassing kim Enduro Suspension 9 02-02-2008 03:07 PM
ohlins rear shock broken! tommo Enduro Suspension 4 05-07-2007 07:15 AM
Suspension fastener and shock problem sn22 Enduro Suspension 1 09-02-2006 12:45 PM
