Went out yesterday for another ride. This is addicting!
First 2 miles was doing good. Trails a bit slick from rain and leaf cover, but was still able to stay in control. Until BAM! Hit a root that I didn't see and grab a hand full of throttle, it stuck! Before I could do anything the bike shot to the left and went up a 3 foot embankment then threw me about 20 feet down the trail on my face/belly! I'm so glad I spent the money on the gear! Get the bike stood back up and shut the gas off. Leaned against a tree and started to see what in the world happened to my throttle. Started to unscrew the cap where the slide goes into the carb. "Click" it opened back up and moved as it should. But upon more inspection when the throttle is turn to 100%, I can hear it click and gets stuck open. I loosened the cap and it stopped that from happening. So now I am wondering if I am missing a seal or rubber o-ring that goes in the throttle cap on the carb? Either way, I screwed it back on and rode for another 25 miles without any issues. Was just a bit more cautious with the throttle and picking my lines better.
"There is no room in life for Regret, it's a useless feeling that leads to a negative attitude" I would rather call it the "Stupid Tax"! |
![]() Quote:
![]() ![]() You might have already done this, but check to make sure the throttle tube isn't getting snagged on something too. I'd pull the slide out and make sure the plastic deal (not sure what it's called) with a notch is fitted correctly - believe this should keep the throttle cable from getting stuck if it's WFO. Make sure the spring still has resistance too and that it's all connected correctly with the needle. I'd also check into getting the Motion Pro throttle cable if it's available for your year. Glad you're ok and the bike didn't seize or have any piston/cylinder damage. |
![]() Quote:
Do you know if there is an gasket or o-ring that goes under the cap and sits between the carb and cap when screwed down? When I had the cap loosened 1/8 turn the throttle doesn't catch, but when hand tightened it catches. Weird!
![]() Quote:
Post a thread in the intake/carb sub-forum and see if one of the guys might have some insight - way more experience peeps out there than me and they might have seen this or know what the problem is. |
On the screw top Keihin PWK carb there is indeed a gasket in the screw top. It comes in a rebuild kit. I believe this kit will work for you: http://www.ebay.com/itm/KEIHIN-CARBU...xVBdxG&vxp=mtr
![]() Quote:
Or just suck it up and get the kit and redo all in the carb while at it?
Went ahead and ordered it. Might as well just change it all and start fresh after all I changed the needles and the bowl screws are crappy. Fresh springs and float needle will be nice too.
Thanks
