Old 01-03-2018, 11:49 PM
CombatYoga's Avatar
CombatYoga CombatYoga is offline
Default Debugging no spark on '14 XC300
In October of 2015 I was coming back to camp at the Zink Ranch NEPG and my '14 GG XC300 quit on me. Was able to determine that it was not sparking and got towed back.
A month or so prior to this, I was having intermittent spark issues. It turned out to be where the wiring harness plugged into the CDI. Someone else on the forum had the same problem and recommended bending the tabs to make a firm connection. That worked, and then I had the failure at Zink Ranch.
Because of the proximity of these events, I have made the assumption that the problem was again this interface. I have monkeyed with it to no avail.
I recently ordered a wiring harness off of ebay and spliced it in. Still no spark.
I purchased an in-line spark indicator with a light that blinks so that I can see if I'm getting a signal to the plug.
Any suggestions on how to proceed on debugging this?
Is there a fuse I should look for to see if it is blown? Is there a way to test the CDI? Could the stator be the problem? How does one test that?
Not very good with a voltmeter, but willing to learn.
Slade
'14 GG XC300R - County Cycle Woods Weapon #63
Old 01-04-2018, 06:45 AM
john r b's Avatar
john r b john r b is offline
Slade, did you remove the starter?? Pretty sure you did, this may have some affect.
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 01-04-2018, 08:27 AM
CombatYoga's Avatar
Hi John,
Good memory! That is correct - I removed all of the e-start stuff from my bike.
But I did that a good while back and the bike ran fine and kicked started fine for a number
of months.
Also, I disabled the kill switch while I am attempting to debug this latest problem to rule it out (cut one of the wires).
Slade
Old 01-04-2018, 08:57 AM
john r b's Avatar
Slade, i bet the cdi is the culprit, my understanding is their are two types
1 for kick only bikes
2 for e-start bikes.
I still have a complete kick only wire harness
'12 XC 200 TTX Sold
Old 01-04-2018, 10:26 AM
dANbOT's Avatar
dANbOT dANbOT is offline
I'm the guy who had the ecu pin issues you mentioned. After replacing the one bad pin socket (12v batt supply to ecu) I haven't had any problems.
I would spend the time checking the wiring for continuity, as I have broken a couple wires over time and abuse. The harness is certainly is not of the highest quality lol
Is your battery fully charged and in good health? That ecu wont do anything without a 12v batt supply
2021 Beta 300RR
2014 Gasgas XC300R
2019 850 Pro RMK
Old 01-04-2018, 04:35 PM
CombatYoga's Avatar
One thing I am doing which is going to showcase my ignorance about electric systems on a bike is I am using the terms CDI and ECU interchangeably. If that is wrong, someone give me a slap. Hopefully I haven't confused the situation.
The part that failed on danBot and then on my bike which we had to fix was the red box mounted in a bracket that says JD Racing Ignition on it.
That is the part that I again suspect to be problematic, though I'm not sure how to test it.
If the CDI is indeed a different part, can someone confirm
1) if there really is a difference between the e-start and kickstart versions
and then
2) where it is located and what it looks like
I will follow danBots advice and start checking wiring and connections.
Slade
Old 01-04-2018, 04:40 PM
CombatYoga's Avatar
Default Battery?
danBot - I removed the battery from my bike when I took off all of the e-start parts. My bike has kick started and run fine until it quit at Zink Ranch.
I am confuzzled!
Slade
Old 01-04-2018, 05:42 PM
Neil E. Neil E. is offline
Download a copy of the 2014 owner's manual. It has the wiring diadgrams for both kick and estart. Compare them and you will see that the kick model has an AC powered CDI (single winding on the stator connects to the CDI).
The estart model has a DC powered CDI (single winding on the stator is not used). It is interesting to note is that both models use the same voltage regulator/rectifier.
The kick model gets a capacitor instead of a battery. This is probably to assist the reg/rect to function correctly. When removing the estart system you should keep the battery (or install a smaller battery if you are after weight savings). Perhaps your reg/rect is no longer working.
Old 01-04-2018, 05:58 PM
john r b's Avatar
Neil, Please explain the differences between the CDI, ECU, and were they are located on the bike. the rectifier is typically close to the head labeled ''leonelli" or something.. Thank you.
so the CDI is under the tank ''red JD racing ignition module" ECU ?
'12 XC 200 TTX Sold
Old 01-05-2018, 12:20 PM
I haven't seen a 2014 GG so I can't advise on the part locations. There are different housing colours so I can't identify your CDI (some people call it an ECU). The reg/rect is easy to spot and should look the same as the 2011 unit.
ec 50 boy no spark D E Enduro Electrical & Wiring 0 09-23-2014 10:29 AM
99 no spark c-152 Enduro Electrical & Wiring 10 06-30-2011 10:23 AM
CDI? No spark tommymoto Enduro Electrical & Wiring 4 02-28-2011 01:22 PM
No Spark.. (i think) Todd5774 Enduro Electrical & Wiring 22 01-21-2011 09:43 AM
Fix for no spark brains Enduro Electrical & Wiring 2 08-14-2010 12:38 AM
