hello i was wondering how much would those part cost for my 2014 ec 300
and where can i get them piston assy and SE bearing gasket assy complete with seal crank bearing.. mag ,,pto crank seal ,, mag,, pto front sprocket.. clip in and out water pump shaft water pump seal water pump impeller water pump bearing i hope some of them come as a kit thanks |
Pistons and gaskets are easily found on ebay. Seals and bearings can be found locally at places that specialize in those (you will need the sizes that you can find at http://www.gasgasmotos.es/en/manuals.html. I would get all water pump items straight from a dealer. I usually use Hall's but there are other fine dealers you can find on the forum that ship parts.
On http://www.gasgasmotos.es/en/manuals.html look under the "exploded" header. Exploded is gasgas talk for parts breakdown. It will be a column of what looks to be little green or grey sprockets. If it is green then they did a breakdown for that year/model. If it is grey for your year model go to the closet year that is green.
thank for the info
GG pro part to fit EC | gassergrant | Enduro Engine - 2 stroke | 4 | 08-24-2012 03:35 PM |
Fse Part , What is it , and where is it from ??? | Gerko | Enduro Engine 4 stroke (including EFI & Exhaust) | 7 | 02-06-2011 07:12 PM |
To part it or not? | PEB | General Discussions & Announcements | 2 | 10-02-2008 05:03 PM |
