Old 11-05-2008, 10:15 AM
cal_tony cal_tony is offline
Default FSE 450 W/ 14t Front sprocket???
In looking at most of the posts on this site I have seen the question asked a number of times regarding the use of a 14 front on the FSE. It also seems like the question has not been answered. Or at least I couldn't find the answer.
It doesn't seem like there is room without some grinding.. There wasn't room on my DRZ for a 16 front but there was enough info on the ThumperTalk site showing how to do it. (Grind the case saver and cut the swing arm rubber) So is there a technique for fitting a 14 front?
Also, some mnfg list the Yamaha yz125 front to be compatible with the GG, The JT catalog says no. So is there something that is avail to fit the GG?
Thanks, tony
Old 11-05-2008, 10:23 AM
slocalspode's Avatar
Bob Piper of North Tahoe Motorsports sells an Iron Man 14 tooth front
sprocket.
http://cgi.ebay.com/ebaymotors/IRONM...mZ140251577476
Not sure if this link will work, but, google for it.
Give him a call or e-mail and ask if it will fit an FSE.
Good luck, Jeff
Old 11-05-2008, 11:58 AM
Thanks Jeff.
Unless Someone informs me that they tried it and could not get it to work, Ill just order one myself. I'm running a 41 on the rear of my FSE now and I'm looking to get a 36 or 37 made up for the rear. Unless someone says it won't work I'll order a 14 as well.
I just had the feeling that surely someone must have tried to fit one by now.
Tony
Old 11-21-2008, 04:51 AM
rstu757 rstu757 is offline
Banned
Talking wow gold
Derek‘s Gold Masterywow gold Guide, is one of the latest World of Warcraft Gold Guides to become available recently. This guide states that it canwow gold help any WoW playerwow gold at any level farm closewow gold to if not more than 150wow gold gold an hour in World of Warcraft.
Old 12-04-2008, 10:39 PM
geoffg geoffg is offline
Thanks, tony
The confision with the YZ125 is simple. The Gas Gas 125 engine uniquely uses a YZ125 sprocket. All the EC/MC/FSE models 200cc and up use the same front sprockets.
I have not tried a 14 tooth sprocket on my FSE450. If it did fit, it certainly would be tight.
Geoffg
Gas Gas FSE450 05
Gas Gas MC125 05
Old 12-09-2008, 09:47 AM
About my question re. the 14t front GG. I have not purchased one yet but will get one of these after the first of the year. Just thought I would post the below listed excerpt from the EBay listing of the Ironman 14. Talon also lists a 14 in there online catalog but I have not been able to find anyone carrying the Talon 14.
My solution to the problem for my SM setup was to fit a DRZ 400 SM wheel to the rear of my GG (see my post on how I did it). The size of the DRZ hub allows for a 36t rear and that seems to be enough for me. After reading the below caution, I'm still not sure I would want to go to a 14.
IRONMAN COUNTERSHAFT SPROCKET 14T FOR 96 TO 08 GASGAS 200,250,300,400,450 EC,XC,DE,MC,SM,FSE MODELS ALL WILD 300 & 450 QUADS. CASE HARDENED TOOL STEEL FOR LONG WEAR & STRENGTH . WARNING 14 TOOTH SPROCKET DOES NOT LEAVE MUCH CLEARANCE BETWEEN SLAVE CYLINDER & CHAIN .IT REQUIRES SOME DREMEL WORK(GRINDING) ON THE SLAVE BODY AND THE CHAIN GUARD - USE AT OWN RISK .CHAIN MUST BE KEPT PROPERLY ADJUSTED AND IN GOOD CONDITION .WE NEEDED THESE FOR TT RACING TO ATTAIN HIGH ENOUGH GEARING TO BE COMPETITIVE IN THE EXPERT CLASS.THESE SPROCKETS ARE A CUSTOM SIZE ,AND ARE NOT AVAILABLE THROUGH GASGAS .
Tony
Front sprocket? wence Enduro Chassis & Body 8 09-18-2010 02:12 AM
front and rear sprocket '07 ec 300 rockrider1 General Discussions & Announcements 12 06-15-2010 07:33 PM
Front sprocket cross over Silver General Discussions & Announcements 3 09-03-2008 08:53 PM
Front sprocket play? Link Enduro Chassis & Body 2 11-04-2007 10:03 AM
14 t front sprocket on 300 EC 2007 Blatchy Enduro Engine - 2 stroke 0 11-01-2007 04:30 PM
