Old 01-25-2007, 09:06 PM
MIKEWA MIKEWA is offline
Question Oil Drain Plug
Is there an after market oil drain plug"steel" that would replace the stock
aluminum drain plug for my 05 de 300? Maybe a crossover from another bike?
thank you, mike
Old 01-25-2007, 09:41 PM
Why? Stripped? It only has to be snug, you should just tighten it with a ball allen key. Install a new o-ring every couple of oil changes and it never leaks. Stick a piece of duct tape over the plug to keep dirt from packing in it.
Old 01-25-2007, 09:48 PM
MattR's Avatar
MattR MattR is offline
Mike,
A new GG aluminum drain plug with magnet is very inexpensive. I replaced mine one time and it was like $6. The aftermarket sells these for japanese bikes for $20. Sometimes our OE parts are very reasonable!
Like GMP mentioned, just snug it up but don't over-tighten it. The oring seals very well. Also, I like to put a little anti-seize on both the drain plug and filler plug threads. This helps minimize the risk of galling/sticking between the aluminum parts.
Matt
Current: 2009 Yamaha FZ1
Old 01-26-2007, 11:51 AM
JTT JTT is offline
I know the plug from a Kawasaki KLR650 fits, because I replaced the giant bugger on my KLR with a GasGas one
Trick is to keep dirt out of the allen hole or remove it before using the wrench. It's deep enough that you shouldn't strip it out unless your using an impact gun to tighten.
Old 01-27-2007, 06:19 AM
Hawkeye Hawkeye is offline
It's aluminum for a reason. Overtighten a steel drain plug and you'll be rethreading the threads in your aluminum case. Antiseize and a gentle hand on the torque levels are good advice.
Regarding the antiseize, my friend had a hard time removing his head bolts from his '03 300EC. Good idea to antiseize these as well, especially with the pre-'04 motors with allen head bolts. I'm a big antiseize proponent.
"Conviction is a luxury of those on the sidelines."
'13 Beta 300RR - race bike
'02 GG300XC - "Billie Baroo"
'01 DR650
'02 GG 280 Pro
'06 YZ 250
'07 WR450
'00 TT125RL
'94 YZ200 - custom keeper
PV left drain plug gasgasquebec Enduro Engine - 2 stroke 8 03-20-2010 06:09 PM
2T drain plug wence Enduro Engine - 2 stroke 0 10-13-2009 04:28 AM
oil drain plug nitroman Enduro Engine 4 stroke (including EFI & Exhaust) 1 08-18-2009 07:32 AM
Oil Drain Plug size Motarded1 Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-22-2008 12:08 PM
Oil drain plug and radiator cap options sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 6 10-04-2007 08:18 PM
