Old 03-11-2011, 01:35 PM
Crankin04 Crankin04 is offline
Originally Posted by Vinny View Post
Now my dealer is frustrated. They have checked all the wiring and obvious stuff.....no results.
They dont have a diagnosis computer; should they ?
It seems to me that if you are a dealer the equipment required to do your job should be available .
Does the GG 450 have a port to hook up a computer diagnosis ??
yes their is a ECU diagnostic program called the Technoresearch VDST Software. Look it up here:
http://www.technoresearch.com/Produc...e_Features.htm
It's $200, and you should just buy it yourself or convince your dealer to get this.
Good luck!
Crankin04
04' GG FSE 450
Live Easy, Ride Hard!
Old 03-16-2011, 10:47 PM
Vinny's Avatar
Vinny Vinny is offline
Thanks for the info. I'll pass it on to the dealer and see if he'll buy one.
Old 03-17-2011, 12:44 AM
bergerhag's Avatar
Does it still run the fuel pump when ignition key is turned on?
Old 03-18-2011, 11:35 AM
Vinny's Avatar
Yes it does. It all works perfect.......except no spark.
Old 03-18-2011, 11:36 AM
Vinny's Avatar
Default Need CDI
My dealer (Austin, TX) cant figure it out still. They think CDI.
Where do I get one ?
Old 03-19-2011, 07:46 PM
bergerhag's Avatar
Here's a test to check pickup coil circuit: turn ignition on, wait for pump to stop. Slowly kick engine over, pump should start again when flywheel passes pickup point.
And there is no separate cdi, it is all handled within ecu/computer.
Old 03-22-2011, 07:39 AM
Vinny's Avatar
Default How much for ECU / computer ? Where ?
Thanks. I'll pass that test on today.
If it is the ECU / computer where do I get one / how much ?
Thanks
Vinny.
Old 03-22-2011, 08:12 AM
bergerhag's Avatar
Thanks
Vinny.
gofasters.com: $614.
http://www.gofasters.com/index.php?m...oducts_id=2736
Or maybe you can find a used one.
Old 03-22-2011, 08:18 AM
bergerhag's Avatar
I had a problem on my 450 once, when starter motor just used too much power, leaving the voltage across battery terminals as low as 9 volts when cranking. This turned out to be below the lowest operating voltage of the ECU, and it was not working. As a result, there was no spark when cranking the engine with starter motor.
However, when cranked using the kick start, I got a good spark, and bike would start just fine.
Try hooking it up to a car battery.
Old 03-24-2011, 01:41 AM
Vinny's Avatar
It would be great if its that easy. I'll pass it on to the dealer.
Any ideas of where to get a used ECU / computer for a 450 ?? $ 600 is above my pay grade
2005 FSE450 wont start itsagas Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-16-2010 08:38 AM
02 EC 300 wont start GENO 300 Enduro Engine - 2 stroke 0 09-21-2009 10:02 PM
EC200 wont start Skele Enduro Engine - 2 stroke 25 09-06-2009 10:34 AM
wont start clerky clerk Enduro Engine - 2 stroke 8 11-01-2008 01:18 PM
2000 Xc 250 wont start In mesa arizona justinmanus Enduro Engine - 2 stroke 9 12-25-2006 04:46 AM
