#101
2010 ec300
Main- 180 Needle- JD Jetting blue.3rd clip Pilot- 38 a/s- 3.5 Motul 800 50:1 sea level to 500m 20-28 degrees C I thought it was good as stock,now it's frikin awesome!! Dropped the float level a little as I was getting some fuel overflow. Fuel economy has been pretty poor,will see if it has changed. |
#102
Bike year & model = 2001 EC300
Temperature (degF) = 50 Elevation (feet) = 500 Main jet = 178 Pilot jet = 42 Needle & notch = LTR - middle Air screw setting = 1.75 Throttle valve/slide = #7 Results: after getting the float set right, this bike will start and idle all day long now. Crisp on idle response, transition from slow jet to main jet is smooth. Using premium pump gas with Belray MC-1 at 50:1 I do have the carbon fiber reeds which also helps make it snappier. It pulls harder and faster than it ever has. Very happy with the results.
07 EC 300 ![]() 06 Gold Wing ![]() (2) 06 CRF 150 F |
#103
Bike year & model = 2011 EC300-E
Temperature (deg C) 25 Elevation (feet) = 200 Main jet = 175 Pilot jet = 40 Needle & notch = N1EF #2 Air screw setting = 1.75 Throttle valve/slide = stock With the 2011 single base gasket it seems broader power than last years model. It has a slight hunting noise when you shut it down, but on a sunny day I can start it cold without choke, so it can't be lean.
EC300 2019 (11 Gassers owned, many more to go) |
#104
Bike year & model = 2010 EC300
Temperature (deg C) 25 - 40 Elevation (m) = 900-1200m (3000-4000ft) Oil = 40:1 (unleaded + Motul 710) Main jet = 175 Pilot jet = 40 Needle & notch = N3Eh #2 Air screw setting = 1.5 Throttle valve/slide = stock (7)
2003 txt250 Pro 2013 Ossa 280i Last edited by swazi_matt; 03-16-2011 at 07:17 AM. |
#105
2011 Gasgas ec 300 es
altitude 3000-5000ft temp 20-30 deg C oil ratio 40:1 95 unleaded pump gas pilot 40 main 168 needle N3EH #2 airscrew 1 3/4 out |
#106
2000 EC200
Location: Singapore Altitude: sea level - but using correction tables due to high humidity works out at between 0 to 500m Temp: 26 to 35 deg C Oil ratio 50:1: Mobil 1 Racing 2T 98 unleaded pump gas Pilot: 38 Main: 172 Needle: JD Red #2 (from top) Airscrew 1 1/4 out Slide 8 Jetting is most suited to about 26 deg C at sea level. Mods: 2003/4 FMF Fatty and Power Core II Big power valve cover Tempa Flow ([url]www.holtzmaneng.com) I also have just fitted a Tempa Flow, this is a gadget that automatically leans off the mixture with rising temperature, this is made possible by changing (lowering) the pressure within the float chamber. A vacuum tapping needs to be added to the carb and the carb vents are all joined together. Both the vacuum and vents connect to the Tempa Flow. Based on temperature the amount of vacuum or atmospheric air is modulated. Only had it installed a couple of days but engine running super smooth - no 4-stroking when its air temps are hot, which was normal when the temperature gets high (now at 32 degC and 60% humidity). Last edited by johnm; 04-10-2011 at 02:44 AM. |
#107
ec300 - unknown year - 02 or before probably
175 main 45 pilot 2 turns out ddk needle at #2 - at #3 i get a stutter at 1/4 throttle.. #7 slide float height at 16mm 1000 elevation. 65 degrees idles and is snappy. will tractor up hills in 4th gear. pulls my 190lb ass around like i'm not even on it. 50/50 mix of 110 and 93 octane. 50:1 amsoil 2k2 ignition + 9 oz fww+xc200 cdi+squish at 1.2mm (hence the race gas - pings on regular gas)) messico pipe
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com ![]() Last edited by stainlesscycle; 04-21-2011 at 02:10 PM. |
#108
2011 EC250 with a PWK 38mm Air Striker 2 carb (Canadian bike). FMF Q stealth silencer, stock pipe, VForce 3 reeds, basically a bone stock bike up here.
Elevation: 2000-3000' 38 pilot jet (stock was 40) 172 main (stock was 180) N8RH needle in the 4th clip Air screw is 1.5-2 turns out depending on air temperature. Plug was a golden tan when tested at 5 degrees celsius but might be a tad rich as the temperature warms up. Once the weather improves and it stops snowing I may drop the pilot to a 35 and see about moving the needle or going to another KTM needle. It seems the KTM jetting chart is pretty close, though because this is a 250 and with a 38mm carb, the jets need to be 1-2 steps richer. For a 300 an engine tuner said it could get away with the stock KTM250 jetting due to the increased air velocities of the bigger jug. |
#109
Finally got my jetting sorted. No more sputtering at all.
Runs really crisp and no spooge. Bike:2011 GG 250 Six Days. Carb-38mm ASII. JD Jet kit. Pilot-42. Main-168. Needle-red-clip in the middle. Air screw-2 turns out. Elevation-80' to 300'. Temp-98F and 90% humidity Last edited by gasgasman; 05-29-2011 at 11:33 AM. Reason: Added elements. |
#110
Bike year & model = 2010 EC300 PWK ASII 38mm
Temperature (deg C) 20-35 Elevation = 600m - 1200m Main jet = 172 Pilot jet = 40 Needle & notch = N3EH #2 Air screw setting = 3 Throttle valve/slide = stock 7 this seems to be working fine for me, possibly look at going down one of pilot as the air screw is fully open
The jetting database needs your help! | MattR | General Discussions & Announcements | 4 | 10-18-2017 05:34 PM |
JD Jetting settings for linear power delivery? | SpeedyManiac | Enduro Intake/Carburetion - 2 stroke | 5 | 04-06-2010 06:17 PM |
Modification/Aftermarket Database | SpeedyManiac | Enduro Product Reviews | 4 | 02-04-2009 07:09 AM |
Jetting Database Announcement | MattR | General Discussions & Announcements | 0 | 12-18-2008 08:58 PM |
Jetting Database Summary | MattR | Enduro Intake/Carburetion - 2 stroke | 0 | 12-18-2008 08:36 PM |
