#11
Checking out the screenshots of the program, they look very much like the program I was using. Thanks for the link. Good Riding! Jim
Jim Cook Smackover Racing Team LAGNAF '11 Gas Gas EC250 (primary ride) '06 Gas Gas DE300 2004 Gas Gas TXT300 Pro '94 Husaberg FE350 '86 Yamaha IT200 '86 Honda TRL200 Reflex '04 KTM 525EXC (soon to be dual sported) Several others, including project bikes, Deb's bike, and a fleet of grandkids' bikes Let's go riding! http://www.jebruns.com/Wudi19/wudi19.html http://www.ahrma.org/schedules-results/cross-country/ |
#12
If you are tech savvy this will do most of the commands for the 15p and m variants and it comes with source code so it can be modded to fully support them. It also has support for the quirky 'K line' interface that our model uses.
http://sourceforge.net/projects/iaw-scan/ You will need to construct or buy the interface ($20 worth of components) to get it working but it may be worth a try if you are so inclined. Also it should be possible to contact the author and have him add the relevant commands/error code interpretation for the bike versions
06 Gas Gas FSE 450 USA 07 Gas Gas FSR 450 UK with motard and dirt wheels |
#13
hi, if you have a kill switch/button that rubber key goes into on the 400 just unplug the wires 2 wires that go to it this by passes the system or at least it does on my 450. one less thing to worry about in the wiring just primes up with ignition turned on.
#14
It's running again
Thanks again for all your advice on this, but It's running again. I decided to just throw all the original equipment back in, including relay and ECU, and it fired right up. Don't ask me why, but I think it might have just been moisture in the ECU. After letting it sit in a cool dry space, case open, for about 3 months.
2003 Gas Gas 400FSE 2003 Honda XR250R 1986 Kawasaki KDX80 1974 Honda Elsinore MT250 |
#15
Hi Headhunter99
I've had the same issue on my 2004 fse 400 & after checking all the electrical connections I found a relay in the airbox compartment with severe corrosion on the contacts. After cleaning this its been fine I also managed to source one for ?6 on ebay (from a fiat punto of all things) |
#16
Any one out thier no were to get quick release fuel couplers for gasgas fse400 2002 both ends one on fuel lines and the other one for top of tank x2 of them thanks johnmc
#18
If you can't get any good information from the above suggestioed sources, the former importer of GasGas motorcycles and parts, https://cpd.direct/ , might be able to assist you in your quest.
Tags |
enduro, fse400, fuel injection, parts, wiring |
Adjusting the Fuel Injection | sanderjavant | Enduro Engine 4 stroke (including EFI & Exhaust) | 25 | 04-12-2022 10:22 AM |
fuel injection fine tuning | bigm2003 | General Discussions & Announcements | 2 | 09-06-2010 04:25 AM |
Fuel cap issues | kendunn | Enduro Intake/Carburetion - 2 stroke | 6 | 06-12-2009 03:52 PM |
2T Fuel Injection | kim | General Discussions & Announcements | 6 | 04-14-2008 09:55 AM |
Fuel Injection | kim | General Discussions & Announcements | 1 | 08-25-2007 05:55 PM |
